Datsalottapower!
thanks, 10krms i wonder if the caravan can hold up, since its not an suv :) i plan on starting the build the 2nd week in may, and plan to finish by the middle of june.
freddy velez
yeah i know,, orginally i was gona stick with 1 sub and 1 amp,, but when i saw the other amp for 310, i wanted to hook both up to 1 18'' solox ,, but then after some thought i decide to do the 2 subs.. i have 1 solox no ,, i just got to get the other one now.
so 10k rms in subs .,, and i will install it in my 05 caravn haha
where u at? i got a solo x for sale
With the alternators you should be fine, maybe a couple more batteries. If I remember correctly these subs wont take 5000 watts daily?
actually i talked to polecat about putting both xx goliath on one 18'' and he said it can take it for burps but not daily.. the 18'' are rated at 5000 rms, 10k peak, but for 5k rms you need alot of space.
plus the new black cones allow for the subs to get wired at 1ohm, so it will be exact with the goliaths. polecat told me that the new cones do 5000 rms as well, just the only thing differnt is the wiring options
freddy velez
Well gl with your build hope everything works out, make sure you do a build log!!
thanks, i will definitly do the build log. im just waiting for school to finish ( may 15) and to get atleast either the sub or the extra alt to start, but i will post it soon
freddy velez
problem with the power supply?
as of right now i got on hand : all the mdf for the build , both xx goliaths , all the wires 1/0, one 18'' solox,, 6 pa speakers, with ma amp for them, and the smaller things like terminals, fuses. and two deka batteries for now.
all i need to get now is another
1)18'' solo x,
2)iraggi alt ( just waiting for the group buy), and have it installed (dual - stock is 160 amp alt, and ill add either a 240, 260 or 280 iraggo alt, depending which has a higher output at idle) and just
3) 1 kinetik 2000 for the front.
If your looking to bump this thing, your going to need more batteries.
For 10kw I highly suggest more than one alternator if you intend to play it very long at maximum output levels. If you don't plan to actually listen to it utilizing the full 10kw you'll probably be alright with one large alternator - but I would do at least a couple Group-31 size AGM batteries.
Running 12kw in my truck with dual powermaster 200-amp alts it drags down to battery voltage pretty rapidly at high volume.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
i plan to get more batteries later, but for now i can only afford the 2000 kinteik for the front and the 2 deka sea mate batteries i got now, and i got a stinger sp800
freddy velez
