Luda Posted November 28, 2006 Report Posted November 28, 2006 I currently have an 80 amp alternator [87 Chevrolet celebrity]. i am running 2 kenwood KAC-9102Ds, 60amp max a piece. i can get a 110A bolt on alternator. would this plus a strong battery be enough to run the system @ full tilt? as it is the voltage drops so low that it turns off @ the dash. i can get a larger one if needed, but the 110A will only cost me like... 50$ and i dont want to start dumpin money into this thing, cuz im working on getting a Seville here soon. 2005 Grand PrixSource: StockFronts: Stock 6.5 ComponentsRears: Stock 6x9Subwoofer: FI BTL 12" Fully optionedSubwoofer amplifier: Kenwood KAC-7203 bridged @ 4ΩEnclosure: 3.41cuft tuned to 33hz
audiofanaticz Posted November 29, 2006 Report Posted November 29, 2006 <- proud seville owner I also liked that mine came with a nice 140 amp alt. Doing the big 3 upgrade will help if you havent done so already. Depending on what size power wire you are using, it could be upgrade to lower the resistence through out the wire. Would you be using the 110 amp plus your stock 80 amp, giving you 190 amps total? or would you just be swapping the 80amp out for the 110 amp? The 30 extra amps will help a bit more, but 190 would be way better.
Dale Posted November 29, 2006 Report Posted November 29, 2006 What kind of power are you running? Amps....subs...everything. Give a little more info so I can help.
dmanson Posted November 29, 2006 Report Posted November 29, 2006 if you can get a 190 then that's what i'd get. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Dale Posted November 29, 2006 Report Posted November 29, 2006 Alternator current ratings are like money in the bank....You can NEVER have enuff. Period.
