pintich Posted July 11, 2015 Report Posted July 11, 2015 Hey guys, was a long time since I was here, but now I'am back And now I need your help. I have got a new system. And it suck B*lls... was running 250wRMS in my old box and it plays batter and louder then this box on 1000wRMS... So my questin is. Can i put my new Ground zero "GZRW 30SPL" in my old box?http://www.ground-zero-audio.com/en/products/subwooferchassis/gzrw-30spl.html (that is the sub) And my old box: Fb = 34 HzVb = 1.75 ft^3External Height = 36 cmExternal Width = 54 cmExternal Depth = 45 cmPort Width = 5.25 cm Whould i blow my sub if i put it in that box? Atm the sub is in the orginal box ( http://www.ground-zero-audio.com/en/products/subwooferboxes/gzrb-120xspl.html ) and it does not even bass in 80% of the music.... and yess i have tunned it right. I am thankful for all your answers have a nice day
_paralyzed_ Posted July 11, 2015 Report Posted July 11, 2015 It should be in a box that the manufacturer recommends for the sub. Do either of the boxes you have meet Ground Zero's recommendation for a box?You won't blow the sub trying your other box.Ground Zero's recommendations- Box recommendation vented 55 Liter / 1.94 cu.ft. - Rohr / Tube 2 x Ø 8 cm / 3.15" - L = 20 cm / 8" Box recommendation sealed 20 - 28 Liter / 0.7 - 1.0 cu.ft
pintich Posted July 11, 2015 Author Report Posted July 11, 2015 Hey, yeah The box it came in 54L and tunned to about 39hz an my old one is 49L tunned to about 34hz. Okej if it won't blow it i might test The old box and see if it plays a bit batter
Joe X Posted July 11, 2015 Report Posted July 11, 2015 I don't see a problem, you could though reverse mount the sub to gain some space inside and be closer to the manufacturer spec.
pintich Posted July 13, 2015 Author Report Posted July 13, 2015 I have now found out that my RCA's is not even pushing out the right power that it should do.... With the gain ALL the way it sends out about 16v to the speaker terminals.... so that is like no power att all when i have it tuned like it should bee. So I will install a new radio in front and run the RCA's from there. (have RCA cables soldered to the bakspeakers right now) so i gues that will give me abit more power allso
Joe X Posted July 13, 2015 Report Posted July 13, 2015 I hope you were using a LOC to interface with the amp from the speakers, It will be a great idea to get an aftermarket HU.
pintich Posted July 13, 2015 Author Report Posted July 13, 2015 I hope you were using a LOC to interface with the amp from the speakers, It will be a great idea to get an aftermarket HU. not 100% sure on what a "LOC" is, but i hade a converter or what its calld a high to low signal converter. is that what a loc is? Yeah it SHOULD be batter using a decent HU Think it will great
reedal Posted July 13, 2015 Report Posted July 13, 2015 Yes, that's what an LOC is. Line output converter. What LOC were you using? Out of curiosity. A new HU would be much better than any LOC. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
pintich Posted July 13, 2015 Author Report Posted July 13, 2015 Yes, that's what an LOC is. Line output converter. What LOC were you using? Out of curiosity. A new HU would be much better than any LOC. I was using this one "http://www.ampire.de/Audio-Accessories/Line-Output-Converter/AMPIRE-High-Low-Converter.htm?shop=ampire_en&SessionId=&a=article&ProdNr=55020&t=2898&c=55&p=55" Think i never will use that again when i fixed my HU hahaha
reedal Posted July 13, 2015 Report Posted July 13, 2015 Yes, that's what an LOC is. Line output converter. What LOC were you using? Out of curiosity. A new HU would be much better than any LOC. I was using this one "http://www.ampire.de/Audio-Accessories/Line-Output-Converter/AMPIRE-High-Low-Converter.htm?shop=ampire_en&SessionId=&a=article&ProdNr=55020&t=2898&c=55&p=55" Think i never will use that again when i fixed my HU hahaha Probably a good idea to not use it again. I personally don't think I'll ever go the LOC route again. I've used them in the past, they're great for cheap installs for those who don't want to spend much money, but after seeing that most do not output a clean signal, if I ever need to retain factory radio, I'll use a DSP. More expensive, but much worth it from what I've seen. Good luck with your head unit decision. Lots of good choices, don't cheap out! SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
