I just checked that fuze on the back that one is fine so in other words I need a new deck
1995 geo prizm lsi 2003 chevy tahoe2 sound qubed HDS34 tuned @ 25hrzs dxspower d1200pioneer deh-x9500bhs<p>130db
Does the deck power up and display work?
Does the H/U internal amp have power output?
Does the H/U outputs have power from them?
Reset the H/U and see if everything remains the same of has something changed.
When trouble shooting things you have to take it one step at a time and eliminate things from a list of possible problems.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Deck turns on
Speakers play music
The RCAs for the sub out I get get no voltage
The front and rear RCAs get 9v out
I read it wrong but I went and got a loner deck and put it in and it still won't play the amp worked before we put it in my truck. It was my buddy's amp so I don't know know any more the subs still read there ohms so I don't think there blowen
Try using the rear output on the sub amp and see if you get something, the amp will have it's own built in crossover so set that for the time being to make sure your getting something from the amp.
EDIT: Double check the voltage going to the amp and make sure it is getting proper voltage, as you may have a loose connection which might give it just enough to power up but not enough to play anything.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
