2 Zv3 12s box design?
Going to be building a box for 2 12" Zv3s on a Banda 5k. Car is a 2002 Grand Prix. I am considering a trunk wall and just welding in bucket seats so I can still have passengers. Need specs for size of box we should do and the best box for the build? How many cubic feet should it be after displacement,and port size? Would like it tuned to around 32 or 34 hertz. If going with a 4th order should I do a 2:1 ratio etc? Any ideas and info is appreciated!
Zv3 12s will work on 2 cubic feet each and if I am not mistaken will fit that trunk without modifications, just fire forward and seal off. Not sure if the 2:1 4th bandpass will fit though.
You probably aren't going to be able to fit an aero port that's large enough without having bends in it.
Builds:
Zv3s actually perform better in smaller than 2cuft of airspace, I have had a pair in 3 different cars and all of the best enclosures I built which were NOT SPL specific were below 2cuft per 12. I would do around 1.5-1.75 per sub after all displacement ported.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Right on man. We talked with some of team aint loud and they recommend starting at 4 cubes after displacement and work our way down if we need to. To be tuned around 34hz what size aero ports would that be if know by chance. Most likely going with a trunk wall
  • Who's Online   1 Member, 0 Anonymous, 445 Guests (See full list)
