Advice on my build guidelines would be highly appreciated
NEWBIE@SQ
Hi Gang,
I am really new at this sort of thing but would love some assistance, advice, positive and negative critism is also welcome. Since this is a learning curve for me I don't really mind as long as no-one is rude. Well long story short is I have an MK7 Fiesta and I am looking at building a really low and powerful street pounder for everyday use.
Equipment:
2x SA 12"
Taramp HD5000 or HD8000
Extra battery
standard HU
Box will be built by me and i will keep you guys posted with regard to the build. Below are the MAX dimensions available for the build and I would like to tune at 30Hz. Any inout will be highly appreciated.
Have some images of BBPro but i can't seem to upload, I will email them to anyone with advise/
VB 4.3cu.ft
Total 4.687cu.ft
fb 30Hz
QL 6.937
F3 82.13Hz
18mm Marine ply
w=350mm
H=498.5mm
L=950mm
Vent
Round both ends flared before flare 113mm after 200mm
Length = 198.4
Diameter = 113mm
According to BBPro the VV = 33m/s
All external dimensions
A single 113 mm port isn't anywhere near enough port area. Two of those ports won't be enough either.
How many watts are you looking to run?
Builds:
According to an earlier post the HD5000 or HD8000 was too much, so I decided to use the 1k6 es at about 1k. But if i can push more power it would be nice, can you suggest port size? Also the box spec is the max i can go. Thanks in advance.
For a 1,000 watts of power I would suggest at least 250 sq cm of port area. For 2,000 watts use at least 380 sq cm. Using more in either case won't hurt.
Builds:
that would mean using an L port or slot port and what i know about these two ports are really dangerous, would you mind guiding me through this process, i really appreciate the time and responses.
Joe X what i was saying is what ui know about them are dangerous, no one has told me they are dangerous... LOL my knowledge on them are little to none. But i have been working on something after doing some reserach and came up with this let me know if i am on the right track. So my port area should be around 350sq cm as per advise, this i worked out as follows for every cu.ft i need atleast 12 sq.in of port area. so my box is 4.6cu.ft x 12 = 55.2cu.cm of port area. So my port length should be 11inch long x 5inch Wide. gives me 55sq.in = 354.8sq.cm... Please advise if i am on the right track...
  • Who's Online   1 Member, 0 Anonymous, 4809 Guests (See full list)
