Jhunt94 Posted August 13, 2015 Report Posted August 13, 2015 he could build a box that was 14 in high x 18 inch wide x 12 in deep with a 3" aero port cut to 13.633 inches to the side and get a 34 hz tuning frequency. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
MatthewBigBossWilliams Posted August 13, 2015 Author Report Posted August 13, 2015 That's pretty fine. even if it needs to be 40 not all of decaf music is stupid low. I mean can 40hz still play 30hz pretty well?
MatthewBigBossWilliams Posted August 13, 2015 Author Report Posted August 13, 2015 plus it doesnt bother me. That means I don't have to double baffle the port and add anything else. the port will keep the box good.
dsw422 Posted August 13, 2015 Report Posted August 13, 2015 he could build a box that was 14 in high x 18 inch wide x 12 in deep with a 3" aero port cut to 13.633 inches to the side and get a 34 hz tuning frequency. that wouldnt be enough port area. with such a small port, he will get port noise.. 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
MatthewBigBossWilliams Posted August 13, 2015 Author Report Posted August 13, 2015 http://www.dcsoundlab.com/level4.html Use that. It tells everything. If I have to have an aero port, it is what it is.
dsw422 Posted August 13, 2015 Report Posted August 13, 2015 http://www.dcsoundlab.com/level4.html Use that. It tells everything. If I have to have an aero port, it is what it is. thats where i got the parameters for it before.. im at work now, but ill come up with another design in the morning for you 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
CstrokerV Posted August 13, 2015 Report Posted August 13, 2015 he has plenty of room to make a 1 cubed box with a 13 sq inch slot port and fit in that area it shouldn't come out more than 2 cubes total.. a 4 x 3.25 inch is only 27.3" long that is a 34 hz tuning even a 15 sq" is only about 32"... have to make more than one bend but doesn't mater that much in his situation my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
dsw422 Posted August 13, 2015 Report Posted August 13, 2015 he has plenty of room to make a 1 cubed box with a 13 sq inch slot port and fit in that area it shouldn't come out more than 2 cubes total.. a 4 x 3.25 inch is only 27.3" long that is a 34 hz tuning even a 15 sq" is only about 32"... have to make more than one bend but doesn't mater that much in his situation when i get home, ill run the numbers and see how much port area is sufficuent in his situation and then design from there 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
CstrokerV Posted August 13, 2015 Report Posted August 13, 2015 15 sq " is plenty for a 10" on 1500 watts he won't always be seeing my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
dsw422 Posted August 14, 2015 Report Posted August 14, 2015 15 sq " is plenty for a 10" on 1500 watts he won't always be seeing where did you come up with 15 sq in?? is that just what u think will work?? no woofer is alike.. 15 may be good for a another 10 but not this one. this woofer has nearly 24 mm of xmax plus 1500 rms (will prolly average 1100 rms).. that is alot of air moving, so i dont think 15 is enough.. ill be sure what will work in the morning. 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
