Inventors, Geniuses, And People Who Have Good Ideas Read Now.
this is wut u were talking about
photovoltaics
http://en.wikipedia.org/wiki/Photovoltaics
it worx basically the same as a leaf as far as i can tell.
thats wut we need. a living car. it makes its own food like a plant from energy from the sun.
the only problem is we would lose our cars in winter
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
it would be cool to see a new generation of semi truck with massive air intake ducts that will power it when cruising at Xxmph. obviously run on diesel at slower speeds, but its the only thing i can think of that spends most of its time cruising at a fast enough mph
-Drew
uhoh_45 said:
yes we can
the turbines are used to power cities.
so now we need to come up with a way for cars to use to air to charge batteries to move the car. and once u get moving itll have a 50 mph wind that it will use. its just making it safe and efficient enough to be practical
what about starting with the the cold air intake.
1 or more fans in the cold air intake could help charge battery's.
I don't think we should get away from useing gasoline or another combustible force to start out with.
Lets not start out with doing a 180 degree turn on how things work just yet.
I feel we should try to make it more efficent first then grow off of that.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
that is wuts trying to happen right now and u see how independant of gas we are.
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
just a thought
What about useing gasoline to start out with, then use a combination of the + and - forces of magnets to help move the piston back and forth with less physical force.(or being pushed only by combustion)
I gotcha but I feel we need to work with proven practices first.(No, I don't think the auto manufactures are taking full advantage of the possibilities that they have at thier dispossal)
i dont feel like reading the whole thread but has anyone mentioned that we are going through an inflation and this could be one of the reasons why gas is going up????
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
just a thought
well that has the same idea as an electric car except using magnetice forces
plus if u use magnetic forces in a piston setup eventually the piston will have to reach equilibrium between the two magnets. however with a v8 type setup there may be enough energy to keep all the pistons close enough to a magnet to be pushed away from it.
but there is another question. how do u create an adjustable speed?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
well no but thats not the point of the thread. sure money is sumthin we'd all like to keep but wut good is money if there is no earth to spend it on? u feel me. this thread is dedicated to producing a type of energy that is completely clean, can reduce our dependance on fossil fuels, and make transportation relatively cheap
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
