Joser714 Posted August 14, 2015 Report Posted August 14, 2015 New here and still learning so i naturally have question about an amp. I would do a google search but it looks like there is a tag on top of another tag ao its hard to figure out. I did google 1100.1 but came up with no results. I currently have 2 4ohm dvc 350rms 10in subs so i want to know if this amp will do the job
deathcards Posted August 14, 2015 Report Posted August 14, 2015 BD1000.1 or BD500.1 not sure on dimensions skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
rebel Posted August 14, 2015 Report Posted August 14, 2015 http://amp-performance.de/1180-Rockford-Fosgate-Power-BD1000-1.html
Joser714 Posted August 14, 2015 Author Report Posted August 14, 2015 Does that mean its 1128 rms or peak? And one more question since to get the most out of this amp it needs to be at 2ohms can my 4 ohm sun be wired to a 2ohm load or do i have to use both coils
n8ball2013 Posted August 14, 2015 Report Posted August 14, 2015 You can run one sub to it at two ohms or both at four ohms. Do not run it at one THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Joser714 Posted August 14, 2015 Author Report Posted August 14, 2015 Ok thanks for the help guys. I don't think I'll be using this amp then since its only 500 and i need i guess 1000 since both of my subs are 350 each
rebel Posted August 14, 2015 Report Posted August 14, 2015 that amp will give you 1100w clean power at 2 ohm
Joser714 Posted August 14, 2015 Author Report Posted August 14, 2015 But with 2 4ohm dvc subs i can either wire it to a 4ohm load or 1 ohm load. This amp was given to me so I'm not really losing anything but i wanted something more reliable than my cheapo kenwood amp
WillistonAudioLabs Posted August 15, 2015 Report Posted August 15, 2015 These are good amps See my videos on YouTube http://www.willistonaudio.com Many tests and demos of OLD and NEW SCHOOL car audio gear! See cool pics on Instagram @oldschoolstereo
STEvil Posted August 16, 2015 Report Posted August 16, 2015 But with 2 4ohm dvc subs i can either wire it to a 4ohm load or 1 ohm load. This amp was given to me so I'm not really losing anything but i wanted something more reliable than my cheapo kenwood amp I'll buy it from you lol MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
