Nick4029 Posted August 15, 2015 Report Posted August 15, 2015 Hey everyone Currently I have a hifonics brx 2400 pushing a zv4 12. I have it on about 1500 watts right now and I have decent voltage drop. From about 13.9v- 13.4v at 2000rpm. And when I'm driving at night I can see my lights are dimming when the bass hits. But when I turned the amp up all the way (but not clipping) my voltage dropped from about 13.5v-12.4v at 2000rpm depending on the notes in the song. My question is what should I upgrade first. Should I 1. Get a new 320amp singer alternator or 2. Get a second battery in the trunk (xs power d3100) I don't have the big 3 done yet but whenever I buy the alternator or battery that's when I will do the big 3. Also how much will the big 3 help?? I have all sky high ofc 1/0. My current alt is a 160amp so not bad for stock. But I will eventually do both the alt and the batt but I only want to do one until I get money to save up for the other. So in your guys opinions what should I do first. Thanks 2011 Chrysler 200s Sundown zv4 12 rev2 2.75ft3 box tuned 32hertz Hifonics brx 2400 Sky High 1/0 ofc power and ground wire Sky High 8 gauge ofc speaker wire Focal auditor 5 1/4 front component speakers Focal integration 6x9 rear deck speakers Stock 160amp alt
reedal Posted August 15, 2015 Report Posted August 15, 2015 Alt > battery And if you turned your amp all the way up, I can almost guarantee you were clipping SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Nick4029 Posted August 15, 2015 Author Report Posted August 15, 2015 Alt > battery And if you turned your amp all the way up, I can almost guarantee you were clipping Not all the way. I set it with an o-scope. I meant to say all the way it could go without clipping 2011 Chrysler 200s Sundown zv4 12 rev2 2.75ft3 box tuned 32hertz Hifonics brx 2400 Sky High 1/0 ofc power and ground wire Sky High 8 gauge ofc speaker wire Focal auditor 5 1/4 front component speakers Focal integration 6x9 rear deck speakers Stock 160amp alt
SnowDrifter Posted August 15, 2015 Report Posted August 15, 2015 Personal opinion, I think you'll see more benefit from the alternator ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Miguels Posted August 15, 2015 Report Posted August 15, 2015 alternator.. get one that is 6 phase hairpin and youre solid. im my opinion. buying a high output alt that is not a hairpin is a waste of money. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Nick4029 Posted August 15, 2015 Author Report Posted August 15, 2015 alternator.. get one that is 6 phase hairpin and youre solid. im my opinion. buying a high output alt that is not a hairpin is a waste of money. what is the difference between one that is a 6 phase hairpin and one that isn't 2011 Chrysler 200s Sundown zv4 12 rev2 2.75ft3 box tuned 32hertz Hifonics brx 2400 Sky High 1/0 ofc power and ground wire Sky High 8 gauge ofc speaker wire Focal auditor 5 1/4 front component speakers Focal integration 6x9 rear deck speakers Stock 160amp alt
SnowDrifter Posted August 15, 2015 Report Posted August 15, 2015 More output at idle, less noise, greater efficiency(less heat).Simple terms: It's the latest and greatest of alternator tech ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
