Box needed
d-nice88
More info about your setup would be handy. What kind of vehicle is it, what amp are you using, what are your goals for the system, what kind of music do you listen to?
Your space is kinda small for two 15"s.
Builds:
d-nice88 your subs are not stock ones as you chose the SPL option, one would need to see parameters for them before deciding what enclosure to make, not really surprised it doesn't sound too good SPL oriented subs on a rather small enclosure.
DUAL 1 | DUAL 2
Fs: 33.6 Hz | 33.6 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.21 | 5.21
Qes: .28 | .28
Qts: .27 | .27
Mms: 261g | 261g
Cms: 0.86mm/N | 0.86mm/N
Sd: 810cm^2 | 810cm^2
Vas: 78.9 l | 78.9 l
Spl: 91.8dB 1W/1m | 91.8dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1500W * | 1500W *
Sealed box: N/A cuft | N/A cuft
Ported box: 3-5cuft | 3-5cuft
Sub OD: 15.625 | 15.625
Cut ID: 14.125 | 14.125
Mounting depth: 8.250 * | 8.250 *
Displacement: 0.21cuft * | 0.21cuft
  • Who's Online   0 Members, 0 Anonymous, 323 Guests (See full list)
