I plan on building a new system with a Rockford Fosgate T2000.1 bd amp, and 2 15 inch FI audio BL sub woofers. I drive a 2000 Dodge durango. I was wondering if i need a new alternator for this build, or could i just use more batteries? MY last system worked well with a powerful battery and a capacitor, but this system is a little bit more powerful. And help or ideas about my power would be great.
Also, will that amp be good enough for those two subs? I have heard a similar system and it was loud enough to perform hair tricks and such *kinda my gaol*.
Im going to say that you should do at least like 1 Big battery in the back IE Kinetik HC2400 or Powermaster D3100 and 1 big battery up front IE Kinetik HC1800 or Powermaster D2400 and at least 2 runs of 0/1 wire and also do the Big three upgrade. It would be a wise thing to get a bigger alt Like an Iraggi 200 amp or 220 amp alternator
Thanks for the response. Could you please be more specific on the big three upgrade? And also, where could i find a guide on how to run wires between batteries?
Lastly, should i be running these batteries in series or in paralleled?
Edited by Dreko44
look at the topic title and you'll see Pinned: How To Do The Big Iii: Tutorial title. as for the batteries run them in parallel bro. run a fuse after the first battery and another before the 2nd.
Edited by dmanson
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Any idea what type of amp fuses i should be using? and should where exactly do i put the second fuse? after the second connection of the battery before i connect to the distribution block?
fuse the wire BEFORE the second battery:
battery+++++fuse (within 18") +++++++++++++++++++++++fuse (within 18")+++++second battery++++++distro block/amp.
and the size fuse depends on your current draw from the amp
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Thanks guys, that really helped out! Now im just trying to decide if i REALLY need another alternator ...And i cant find one that fits the specs of my car. 2000 Dodge Durango 5.2l If anyone knows what alternator i can use, please let me know
  • Who's Online   0 Members, 0 Anonymous, 3333 Guests (See full list)
