Dreko44 Posted April 13, 2008 Report Share Posted April 13, 2008 I plan on building a new system with a Rockford Fosgate T2000.1 bd amp, and 2 15 inch FI audio BL sub woofers. I drive a 2000 Dodge durango. I was wondering if i need a new alternator for this build, or could i just use more batteries? MY last system worked well with a powerful battery and a capacitor, but this system is a little bit more powerful. And help or ideas about my power would be great. Also, will that amp be good enough for those two subs? I have heard a similar system and it was loud enough to perform hair tricks and such *kinda my gaol*. Quote Link to comment Share on other sites More sharing options...
Aaron813 Posted April 13, 2008 Report Share Posted April 13, 2008 Im going to say that you should do at least like 1 Big battery in the back IE Kinetik HC2400 or Powermaster D3100 and 1 big battery up front IE Kinetik HC1800 or Powermaster D2400 and at least 2 runs of 0/1 wire and also do the Big three upgrade. It would be a wise thing to get a bigger alt Like an Iraggi 200 amp or 220 amp alternator Quote Link to comment Share on other sites More sharing options...
Dreko44 Posted April 13, 2008 Author Report Share Posted April 13, 2008 (edited) Im going to say that you should do at least like 1 Big battery in the back IE Kinetik HC2400 or Powermaster D3100 and 1 big battery up front IE Kinetik HC1800 or Powermaster D2400 and at least 2 runs of 0/1 wire and also do the Big three upgrade. It would be a wise thing to get a bigger alt Like an Iraggi 200 amp or 220 amp alternator Thanks for the response. Could you please be more specific on the big three upgrade? And also, where could i find a guide on how to run wires between batteries? Lastly, should i be running these batteries in series or in paralleled? Edited April 13, 2008 by Dreko44 Quote Link to comment Share on other sites More sharing options...
dmanson Posted April 13, 2008 Report Share Posted April 13, 2008 (edited) Thanks for the response. Could you please be more specific on the big three upgrade? And also, where could i find a guide on how to run wires between batteries?Lastly, should i be running these batteries in series or in paralleled? look at the topic title and you'll see Pinned: How To Do The Big Iii: Tutorial title. as for the batteries run them in parallel bro. run a fuse after the first battery and another before the 2nd. Edited April 13, 2008 by dmanson Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
Aaron813 Posted April 13, 2008 Report Share Posted April 13, 2008 The battteries are just pos and pos neg and neg dont forget to fuse your positive wire in the front and in the back Quote Link to comment Share on other sites More sharing options...
Dreko44 Posted April 13, 2008 Author Report Share Posted April 13, 2008 Any idea what type of amp fuses i should be using? and should where exactly do i put the second fuse? after the second connection of the battery before i connect to the distribution block? Quote Link to comment Share on other sites More sharing options...
roscoe1129 Posted April 13, 2008 Report Share Posted April 13, 2008 fuse the wire BEFORE the second battery: battery+++++fuse (within 18") +++++++++++++++++++++++fuse (within 18")+++++second battery++++++distro block/amp. and the size fuse depends on your current draw from the amp Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER Link to comment Share on other sites More sharing options...
Aaron813 Posted April 13, 2008 Report Share Posted April 13, 2008 Here is a diagram i drew up a little while ago Kind of a shitty drawing but you get the idea Quote Link to comment Share on other sites More sharing options...
Dreko44 Posted April 13, 2008 Author Report Share Posted April 13, 2008 Thanks guys, that really helped out! Now im just trying to decide if i REALLY need another alternator ...And i cant find one that fits the specs of my car. 2000 Dodge Durango 5.2l If anyone knows what alternator i can use, please let me know Quote Link to comment Share on other sites More sharing options...
Aaron813 Posted April 13, 2008 Report Share Posted April 13, 2008 Email Dom i forgot his email adress but im sure he has one that fits your durango Quote Link to comment Share on other sites More sharing options...
