2.4k amps
MusicHead804
That's going to be expensive.
If you're lucky and catch a great deal on a used amp it will still be over $500.
2400 watts at 2 ohm doesn't come cheap, you basically need a legit 5k plus @ 1 ohm amp to get that power at 2 ohm.
What are you trying to power with the amp?
You bought the dual 2 ohm versions im guessing?
What kind of budget do you have to work with?
Also have you considered running two amps at 1 ohm each amp?
You could probably do two 1k at 1 ohm amps cheaper than 1 2.4k at 2 ohm.
Alpine MRX-M240, or kicker 2500
Possibly, depends on his budget.
The Rockford t2500 bdcp would do the trick too but those are all expensive amps.
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
