Amp is set with a dd1 at 40hz -2.5 db pioneer hu does not clip at 39 out of 40. Set with remote bass control set at max. With volume at 39 and remote at 75% I get some flashing at 100% a little faster flash of clipping but never really soild flashing. So should it be safe?
If you set everything right with the DD1 then I wouldn't worry about the clip light on the remote....
its a Sundown scv 1500 on stock electric with big 3. -5db really lights up the clipping light so I went with -2.5db .. Should -5 40hz be OK with that electric?
I suggest setting it with that knob 100%, if I am not mistaken, that is a gain knob. So where ever the gain is set to, that knob acts as a 100% to that mark you set. So if you set the gain with it at 75%, then go to 100%. You are going past the point of distortion you set and are/can induce distortion. Just the way I do it though.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • 9 years later...
Posted (edited)
What if the PTR light blinks a little on the bass knob? Is this fine an can i still turn the volume up a little? I got the big 3 upgrade with a 320amp HOA, with two sundown u12 v2 powered by the sexy salt 4.
Edited by Drizzt777
cool reasons
Posted (edited)
On 8/20/2025 at 6:52 PM, Drizzt777 said:
What if the PTR light blinks a little on the bass knob? Is this fine an can i still turn the volume up a little? I got the big 3 upgrade with a 320amp HOA, with two sundown u12 v2 an 4000wat sundown amp.
I am giving you a hard time you goof ball
Edited by SnowDrifter
