MusicHead804 Posted September 7, 2015 Author Report Posted September 7, 2015 if i use it on subs you think it would do what i want ?
jcarter1885 Posted September 7, 2015 Report Posted September 7, 2015 What in the actual fuck is going on here? Sorry I should of used smileys to back my sarcasm. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Broke_Audio_Addict Posted September 7, 2015 Report Posted September 7, 2015 if i use it on subs you think it would do what i want ? Should I just guess what it is you want it to do? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
MotorCityFats13 Posted September 7, 2015 Report Posted September 7, 2015 300A Fuse. 10-500Hz Variable High. 50Hz-15KHz Variable Low. 0-12dB Bass Boost. 45Hz, 12dB Bass Boost Frequency. <0.7% THD. >90dB StN Ratio. 10Hz-15KHz Frequency Response. 1-Ohm Impedance. 10-15 Operating Voltage. 92% Efficient. 8V-0.2V Input Sensitivity it has high pass and low pass and bass boost.... my guess would be you can hook this to a multi cabinet line array for a mobile concert truck... 2 or 4 of these you could build a concert stage on a flatbed trailer!
MusicHead804 Posted September 7, 2015 Author Report Posted September 7, 2015 Will it give me the bass that i'm looking for? would it sound better than the shitty power acoustik 6000d i got right now
islandpride684 Posted September 7, 2015 Report Posted September 7, 2015 https://instagram.com/p/7JseWgEt5N/?taken-by=meade916 Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
islandpride684 Posted September 7, 2015 Report Posted September 7, 2015 so they dont do rated better than that PA you're running... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
MusicHead804 Posted September 7, 2015 Author Report Posted September 7, 2015 so they dont do rated better than that PA you're running... true, but dude just said its for mids and highs tho
islandpride684 Posted September 7, 2015 Report Posted September 7, 2015 so they dont do rated better than that PA you're running... true, but dude just said its for mids and highs tho you can use it for mids and highs or for your subs...too many good brands out there just up to you if you want to spend that mula...I saw this one Meade's insta page.... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
