what size fuse do i use?
Imo the fuse should be as close to the equipment needs and the wire for it needs to at least handle that amount of current. I know 12awg is good for 20 amps and 14awg is good for 15 amps. The fuses for that size wire should never be bigger than that
Should i run everything off of remote wire then relay or would it be safer to run separate amps on remote and fans on their own wire with switch plus should i fuse the remote wire? I'm having trouble finding information on how to run amps and fans.where can i find good info on this.
Problem solved.
Get the turn on relay kit.
The tork2 is what you need.
http://m.ceautoelectricsupply.com/?url=http%3A%2F%2Fwww.ceautoelectricsupply.com%2F&utm_referrer=#2825
They even offer a discount for smd members.
Thank you wow absolutely perfect torx2 is perfect (thanks again everyone)
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
