Help on a alarm with a cut off switch
Do you want remote start or a theft prevention/lockout system? What they are saying is you don't get both.
Ok np I just thought you can use a relay to send power or ground to bypass the switch but wen the car finish warming up or the alarm is shut of you will still need to hit the switch
THe way the remote start alarms work is that when you activate the remote start the engine runs for a set period of time and the engine will shut off if the brake is pressed without the key in the ignition. No key = no drive.
Get a nice compustar with drone which u can start from your smart phone an track it constantly with gps
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
