Singer alternator in a Mazda 6 problem
Is that a computer controlled alt?
Also do you have your big 3 done?
Yes sir, i have the big 3 with tool maker battery termanals on a optima yellow top, Mike made the harness to bypass the computers regulator so the alternator can get more field current to charge higher constantly.
Well apparently whatever he did isn't working properly so I would contact him to resolve the issue.
Yeah as i said i sent him an e mail but hes so busy it takes him 3 or 4 days to get back to it, i hoping someone will see this post that has a mazda 6 with a singer alternator for a bit faster help, thank you for you're replys though.
If you mess with something on your own you are likely going to void your warranty
If you installed the bypass correctly, it shouldn't be that.
If the pulley ratio changed from stock, you likely need a smaller belt.
Singer Alternators
Team Asshole
#anothershittysingerbuild
Yeah the belt is very tight and it doesnt slip at all, Mike said its a pretty efficient alternator and will putout 200amps at 800 rpm, and he gave me instructions on how to install the bypass harness but i have a feeling something is in the wrong spot or something.
Never mind on this whole thing i ended up fixing the problem i had, it was the alternator turn on wire not connected right, it was connected to the computers PCM regulator so it was getting confused and turning the alternator on and off constantly.
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
