4 channel amp overheating
ctq
hello I have a old alpine flex 4 MPR-F306 run just door speakers
MB Quart DK1-169
MB Quart DC1-216 component set
The amp is not bridge just one speaker to one channel and the amp is over heating.
Not sure why all speakers are 4ohm specs said it can run 4 ohm load.
Was think that the component set is changing the ohms since its 2 speaker to channel when wired.
does the tweeter and woofer in a component change the ohm like dual vc subs?
Amp is mounted under passenger seat it that helps.
You can always check the impedance at the amp if you're not sure. How good is your ground?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Are you running the passive crossover with the component set?
Running the factory crossover that came with the component set. I don't see any reason why it would over heat and on top of it over heating its doing it fast as if I had the amp bridge at 2ohm load. so one song its overheating .
How high is the gain turned up and where is the amp located?
Pictures usually help us determine issues.
Gain sitting at 3/4 up and yes to the point of turning off red hot!!
amp is sitting under passenger seat.
The gain being that high is your problem.
IDK the amp says it can take a 4 ohm load it shouldn't over heat that fast in a open air environment like under a seat not like its smashed there.
I ran my MB Quart raa100.1 @ 1 ohm maxed out on a American bass xfl 1222 sub and it never over heated needless to say after running the amp @1ohm for 9 yrs it fried on me last week but 1ohm is hard on amps and 9 yrs is a long time for a amp. Was a great amp by the way it will be missed!
  • Who's Online   0 Members, 0 Anonymous, 867 Guests (See full list)
