BoomZoom808 Posted October 8, 2015 Report Posted October 8, 2015 Can someone help me out with a ported box design for a pair of PPI PRO 124's? This would be for a 05 Mazda 3i trunk and the amp I will be using is a Soundstream TA1.2000D for power at 1 ohm Thiele/Small ParametersFs (free-air resonance, Hz) 42.26Vas (equivalent compliance, cu. ft.) 0.656Vas (equivalent compliance, liters) 18.58Qms (Q, mechanical) 7.68Qes (Q, electrical) 1.03Qts (total driver Q) 0.91Re (DC resistance, ohms) 5.8Z (nominal impedance, ohms) 2 x 4Le (inductance, mh) 1.47Efficiency (1W @ 1M, dB) 83.23Xmax (one way linear excursion, in.) 0.91Xmax (one way linear excursion, mm) 26.5Pe (continuous power handling, watts) 1000Peak power handling (music, watts) 2000Mms (total moving mass, grams) 260Cms (mechanical compliance, mm/N) 0.055Bl (motor strength, Tesla-M) 19.72Sd (effective radiating area, sq. cm.) 491.03Sd (effective radiating area, sq. in.) 76.11Frequency range (Hz) 42-250Energy Bandwidth Product (EBP) 41Driver Physical DimensionSpeaker Outer Diameter (inches) 12.44Speaker Outer Diameter (mm) 316Mounting hole diameter (inches) 11.06Mounting hole diameter (mm) 281Mounting depth (inches) 8.07Mounting depth (mm) 205Magnet Weight (Oz) 155Basket diameter (inches) 12.44 Thanks! 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
BoomZoom808 Posted October 12, 2015 Author Report Posted October 12, 2015 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Triticum Agricolam Posted October 12, 2015 Report Posted October 12, 2015 What are the max dimensions of your space? What kind of music do you listen to? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
BoomZoom808 Posted October 13, 2015 Author Report Posted October 13, 2015 What are the max dimensions of your space? What kind of music do you listen to? Thanks Triticum, the max space is 36" w x 17.25" d x 15.75" h and I like to listen hip hop, country, reggae, decaf, dj snt... I have built a few boxes tuned between 33-40hz for this vehicle and have been happy with the response. The suspension on these subs is stiff so I am not too worried about playing under tuning. I have one of the 12's right now in a box that is 2.75 cubes after displacement tuned to 34hz on 1k and it has not bottomed out and it still hits the lows pretty well. I think a pair in the right box will hit pretty well. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Joe X Posted October 13, 2015 Report Posted October 13, 2015 You don't have enough space for a 4 net box on those dimensions, you may want to see if you can get some extra space.
BoomZoom808 Posted October 13, 2015 Author Report Posted October 13, 2015 You don't have enough space for a 4 net box on those dimensions, you may want to see if you can get some extra space. Does it have to be 4 cubes? I have no idea what's recommend for this sub. Manual only gives sealed recommended specs at .9 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Joe X Posted October 14, 2015 Report Posted October 14, 2015 The sub specs are for sealed, there should be about 3 cubic feet net for the pair in a ported box.
BoomZoom808 Posted October 16, 2015 Author Report Posted October 16, 2015 I am going to try for 3.5 cu tuned to 35-36hz with 60 in of port area 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
