Joe Kralovetz Posted October 9, 2015 Report Posted October 9, 2015 15" H x 33" W x 25" D with a 2x 7" x 14" aero port Would these measurements work for 2 x12 v2s D4s? biggest I can go is 15" high x 35" wide and 40 depth anyone got any ideas for box dimensions? 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Joe Kralovetz Posted October 11, 2015 Author Report Posted October 11, 2015 Bump 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Triticum Agricolam Posted October 11, 2015 Report Posted October 11, 2015 What amp? You are probably low on port area, but that will depend on how much power you are going to be running. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joe Kralovetz Posted October 11, 2015 Author Report Posted October 11, 2015 What amp? You are probably low on port area, but that will depend on how much power you are going to be running. SCV-3000D at 1 ohm on decent electrical to power it. So about 3k daily 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
Triticum Agricolam Posted October 11, 2015 Report Posted October 11, 2015 Sundown recommends 40 sq in of port per sub. More than that wouldn't hurt either. If you have two 7" aero ports that should work well. Otherwise I'd probably use a slot port of around 100 sq in. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
CleanSierra Posted October 11, 2015 Report Posted October 11, 2015 Where are you getting a 7" aeroport? Im not the one you want to try to troll. Just a fyi for you.
Joe Kralovetz Posted October 11, 2015 Author Report Posted October 11, 2015 Sundown recommends 40 sq in of port per sub. More than that wouldn't hurt either. If you have two 7" aero ports that should work well. Otherwise I'd probably use a slot port of around 100 sq in. I was thinking perhaps in that case 2 8"x14" aero ports in the specs of the box I listed then instead.. reasoning for the 15" height is because my of my trunk as I don't want to have to build the box in my trunk and 15" would allow me to slip it in. I'm not sure the program I used is accurate why I came here asking around so how does 15" H x 33" W x 25" D with a 2 -8" x 14" aero ports sound for 2 x12s v2 d4s on 3k daily sound? 2007 Chevy Equinox Pioneer AVH-X5800BHS Big 3 2 runs of 2/0 Welding cable 2 - XS Power D3400 Batteries in Parallel - Fused at 250A Alpine MRP-2000D - Temp amp. 1 - ZV4 15" Rev 1
ToNasty Posted October 11, 2015 Report Posted October 11, 2015 Where are you getting a 7" aeroport? Psychoport makes one. ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
CleanSierra Posted October 11, 2015 Report Posted October 11, 2015 Good luck getting a reasonable tune for 2 12s with 2 8" ports. The box would have to be huge to get a low enough tune. Also, I don't know WHAT you're referring to by saying '2 8" aero ports'. PSP doesn't make 7 or 8" aero ports. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted October 11, 2015 Report Posted October 11, 2015 Where are you getting a 7" aeroport?Psychoport makes one. Last I checked, Lolo took a break from making them. And if OP was referring to Psychoports, I figure he would have used it by name. Im not the one you want to try to troll. Just a fyi for you.
