Need help on a Box for 2 x12 v2 d4s
15" H x 33" W x 25" D with a 2x 7" x 14" aero port
Would these measurements work for 2 x12 v2s D4s?
biggest I can go is 15" high x 35" wide and 40 depth anyone got any ideas for box dimensions?
2007 Chevy Equinox
Pioneer AVH-X5800BHS
Big 3
2 runs of 2/0 Welding cable
2 - XS Power D3400 Batteries in Parallel - Fused at 250A
Alpine MRP-2000D - Temp amp.
1 - ZV4 15" Rev 1
What amp? You are probably low on port area, but that will depend on how much power you are going to be running.
Builds:
SCV-3000D at 1 ohm on decent electrical to power it. So about 3k daily
2007 Chevy Equinox
Big 3
1 - ZV4 15" Rev 1
Sundown recommends 40 sq in of port per sub. More than that wouldn't hurt either. If you have two 7" aero ports that should work well. Otherwise I'd probably use a slot port of around 100 sq in.
Builds:
I was thinking perhaps in that case 2 8"x14" aero ports in the specs of the box I listed then instead.. reasoning for the 15" height is because my of my trunk as I don't want to have to build the box in my trunk and 15" would allow me to slip it in. I'm not sure the program I used is accurate why I came here asking around so how does 15" H x 33" W x 25" D with a 2 -8" x 14" aero ports sound for 2 x12s v2 d4s on 3k daily sound?
2007 Chevy Equinox
Big 3
1 - ZV4 15" Rev 1
Good luck getting a reasonable tune for 2 12s with 2 8" ports. The box would have to be huge to get a low enough tune.
Also, I don't know WHAT you're referring to by saying '2 8" aero ports'. PSP doesn't make 7 or 8" aero ports.
  • Who's Online   1 Member, 0 Anonymous, 303 Guests (See full list)
