Sq help please
g2shuck
I'm hoping you can help me extract the maximum sq from my current build. And by sq i relize its not competition sq lol. I have a set of jbl p660c (very high reviews on diyma) that will be ran passive on a zapco st-2x at 2 ohms. The mid will be installed in the factory location with deadener and ccf of outwr skin and inner skin will be sealed with deadener to seal off the door. I will also be using the FAST three piece acoustic ring kit and making abs adapters like mark at caf did. The part I am needing help with us where would be the ideal location to mount the tweeters. It's a 99 grand am but I can do glass work if need be. The second question is should I high pass at 60hz or 80hz?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Tweeters are something that people need to hear for themselves. It's really personal preference. Grab some double-sided tape and throw em in different locations. This is going to be more important to do since you're going passive, you won't have as much control over them later on. If you just want to plop them in and run with it, A pillars is a safe bet.
Your LPF is going to depend on what your sub can do, but if the JBLs can handle 60Hz at the power levels you want and enough mid bass is there then it's fine. You can decide that later though.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Factory my a pillars point towards the center of the windshield would that change your opinion any?
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
That's how I have my 2 sets of crescendo rts-1s low on a pillars aiming towards center of windshield. I like it but that's me it's all up to your ears.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Does aiming towards center of windshield off axis effect left right imaging?
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Are you planning to use time alignment ??
No time alignment at this point in time. Trying to get my feet wet with proper placement and install before deciding if I am interested enough to get into a dsp and active front stage
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
active has nothing to do with time alignment ... placement though, has everything to do with it. Can't have proper placement without it.
... unless you go 5.1
Care to elaborate on that please? At this point I'm leaning towards a pillars towards center of windshield since my left sail panel is blocked by odd shaped are vent
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
The further apart the components get from each other, the more "out of phase" they become.
... and the more distinct they become. You need time alignment to bring everything back together.
Most component manuals say while you can move things around, they need to stay as close to each other as possible for a seemless transaction of frequencies.
Without time alignment, you will most likely put your midbass drivers out of phase with your tweeters to get any type of stage presence ... which is what I hope you are looking for ...
  • Who's Online   0 Members, 1 Anonymous, 2003 Guests (See full list)
