Crossovers doing strange things
Wasteland_Audio
So i just installed 2 sets of kicker components, fronts are cs series 6.5" and rears are ks series 5.25". When i hooked them up to the amp the crossovers for the rears started to light up at higher volume. I turned the gain down until they stopped but can someone explain to me what that was? it doesn't say anything about it in the manual and they were super bright, i'm new when it comes to mids and highs so idk whats going on with these.
You turned the gain down? Was it properly set? Sounds like you had the gain maxed out and was overheating your crossover internals.
Might be the tweeter protection circuit using a bulb to protect the tweeter from being overpowered and blowing.
I have never used kicker before so it is just a guess without knowing anything about how they build the crossovers.
EDIT: After seeing the video on sonicelectronix site it looks like they are using a pair of bulbs.
http://www.sonicelectronix.com/item_76198_Kicker-41KSS54-KSS54.html
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Get a dd-1 and reset it. Sounds like gain was set to high.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
yea i did a little research myself and found the same thing, for some reason the gains were maxed out when the amp was shipped to me so that's why i had to turn them down right off the bat. the crossovers have resister bulbs in them to protect the tweeters, i turned my head unit to my max listening volume then turned the gain up til they started to flash, then turned the gain down a little bit until they didn't light up anymore, that'll have to do until i can get my hands on a dd-1
The lighting is normal to protect the tweeters from being over powered and blowing, and i'm sure you'll see them light up even after you use a DD1 on the amp.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
  • Who's Online   0 Members, 0 Anonymous, 735 Guests (See full list)
