Anand Sayroo Posted December 6, 2015 Author Report Posted December 6, 2015 OP a couple of questions, 1 What tuning you had for the t-line? 2 only 19" deep? It would seem to me that you should model the tline and base your ported design on that. It was tuned around 30 hz and no, the van has a hole where the 3rd row seat usually folds. the width of the hole is 41 inches, and the depth in this case is the other dimension which is in other words the length which is 19 inches. the Height or depth if you wanna think of it is 58 inches. Theres more space but i dont want to go higher.
Joe X Posted December 6, 2015 Report Posted December 6, 2015 Here is a suggestion, check the dims will work in your space, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide:
Anand Sayroo Posted February 29, 2016 Author Report Posted February 29, 2016 Here is a suggestion, check the dims will work in your space, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide: Hey joe, the depth of the box is a bit more than what i can fit. I can fit 19 inches but this design has a depth of 29.5. I have an endless amount of space for the height.
