You could do a pressure mount, where wood/material presses against the top and bottom of vehicle or sides of vehicle and support that way? You can also make a horizontal platform with a vertical piece to mount amps on, a simple fiberglass job would also work.
-Nick
i've always used a 2" wide strip of 1/2" mdf CA glued than adjust the amps to mount onto those strips. the CA glue I use is Fastcap Gel.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
surprised nobody has said loctite PL premium. that shit doesn't mess around.
go ask hunter..raptorman...
