Mechman 370a installed and Big 3-Highlights and Interior dimming/voltage drop badly
I'm talking about the ground that goes through the battery sensor. If they both can't fit in the sensor hole then where do each go?
HU: Pioneer 4100 NEX
Subs: 2 Rockford Fosgate R2SD4-10"
Amp: Rockford Fosgate P500-1bd wired @ 1ohm
Front: Polk Audio Components DB6501
Amp: Pioneer GM A5602 wired @ 4 ohm
Rear: Polk Audio Coaxials db651s
(2) OM-1s, (1) VM-1
Im not understanding this or maybe we missing each other. If I were to do the big 3, the wire that currently goes through the sensor, where would I put that if the new one from the big 3 needs to go through the sensor so as to not cause problems?
(2) OM-1s, (1) VM-1
Ahhh! Much better, thanks! I assume you are not very fond of the Big 3 upgrade on your truck?
(2) OM-1s, (1) VM-1
  • Who's Online   0 Members, 0 Anonymous, 1203 Guests (See full list)
