Brandon Scobee Posted December 1, 2015 Report Posted December 1, 2015 I have a 99' Toyota Tacoma extra cab that im putting 2 SA-12's in on a SCV-2000, if anyone here could give me some pointers or point me in the right direction on this box build it would be greatly appreciated, thanks guys
crispy_chick3n Posted December 1, 2015 Report Posted December 1, 2015 need measurements of the space you have to work with in the truck This page is crispy_chick3n approved. © crispy_chick3n inc
300824 Posted December 1, 2015 Report Posted December 1, 2015 hope you have the electrical to support that scv 2000!!!
Brandon Scobee Posted December 1, 2015 Author Report Posted December 1, 2015 I'll have 2 xsD3100's, and a high output alternator, my max dimensions to work with are 50W 19H 19D,again its for a extra cab tacoma, should the subs face forward with port forward? Or subs up with port up? I just want it to slam
Joe X Posted December 1, 2015 Report Posted December 1, 2015 Here is a suggestion, subs up / port sideways (usually passenger's), power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide:
Brandon Scobee Posted December 1, 2015 Author Report Posted December 1, 2015 Thank you soo much JoeX, I was hoping you would see this and reply, you are the man bro, I really really appreciate the help sir
Joe X Posted December 1, 2015 Report Posted December 1, 2015 You're welcome, any questions you may have let me know.
Brandon Scobee Posted December 2, 2015 Author Report Posted December 2, 2015 Before I go any further, I sincerely appreciate the help, I talked to steve today and there has been a change of plans, 2 SA-15's is the final decision, same amp and power, sorry to change it up, is it possible to have the port on top with the subs as well, I would like to play with the box once its in the truck, subs up port up, then subs forward port forward just to see if there is a difference, once again, I really appreciate any info or pointers, this is my first real build
Brandon Scobee Posted December 2, 2015 Author Report Posted December 2, 2015 I guess I'll just have to stick with the 12's then hahahaa.
Joe X Posted December 2, 2015 Report Posted December 2, 2015 Here is a suggestion, subs up / port up for SA-15s, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide:
