active tweeter help budget $120
Rich Schenk
want to run some dome tweeters up front to replace my blown crescendo rts-1s had 2 sets two in each a pillar aiming at the glass but now have 1 that still works perfect and another that half works. (thinking this was to user error because of crossover setting because this is my first fully active setup.) my amp for tweeters is a skar sk 85.4 85x4 @ 4 ohms, 125x4 @ 2 ohms, 250 x 2 @ 4 ohms bridged. have my mids crossed at 2.5k
strongly thinking
Morel MDT29 Specs:
Nominal impedance: 4 ohm
Sensitivity: 92dB
Resonance frequency: 1000Hz
Dcr: 3.6 ohm
Mms: 0.45g
Sd: 6 cm2
Power: 80W
Flange diameter: 94mm
Cut out diameter: 72mm
Depth from back of flange: 27mm
1 on each side where ever i can fit these
ScanSpeak Discovery R2604/8330 Tweeter Dual
  • Dual Ring Radiator Diaphragm (Patented)
  • Wave-guide center plug (Patented)
  • Extended frequency to above 40kHz
  • High Sensitivity - 92dB
  • Low Resonance Frequency - 440Hz
  • Low Distortion
  • Double Magnet
  • Rear Chamber
  • Copper Clad Alu-wire
  • 100 watts rms
  • 4ohms
Tymphany BC25SC08-04 1" Silk Dome Neodymium Tweeter with Waveguide 4 Ohm
Product Specifications
Tweeter TypeSoft Dome
Cone / Dome Diameter1"
Impedance4 ohms
Power Handling (RMS)100 Watts
Frequency Response2,500 to 20,000 Hz
Sensitivity98.8 dB 2.83V/1m
Thiele-Small Parameters
Resonant Frequency (Fs)1660 Hz
DC Resistance (Re)2.8 ohms
Voice Coil Inductance (Le)0.02 mH
Mechanical Q (Qms)4.9
Electromagnetic Q (Qes)1.53
Total Q (Qts)1.17
Mounting Information
Overall Outside Diameter2.75"
Cutout Diameter1.75"
Depth1.32"
1 on each side
Tymphany BC25SC06-04 1" Textile Dome Tweeter
Impedance4 ohms
Power Handling (RMS)50 Watts
Frequency Response1,350 to 30,000 Hz
Sensitivity96 dB 1W/1m
Resonant Frequency (Fs)1,350 Hz
DC Resistance (Re)2.9 ohms
Mechanical Q (Qms)2.80
Electromagnetic Q (Qes)2.30
Total Q (Qts)1.26
Cutout Diameter1.70"
Depth1.25"
2 of these on each side
really leaning toward morels but just concerned that they our not going to be loud enough. ive been researching this for over 2 weeks and ready to pull the trigger on something dont want super tweeters or any tweeters that our going to more or less kill my ears. these tweeters have to over power my 4 amercian bass xfls on my dc 5k so i need them to keep up with that. ty for your time for looking and if you have any other ideas let me know or pm because i feel totaly lost right now.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Bump
Need help suggestions
I still vote SB Acoustics SB29RDNC-C000-4
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
What is it's playable frequency range?
Rms rating?
what would I set my crossover to on my 80 prs?
Rms rating?
http://www.sbacoustics.com/index.php/products/tweeters/ring-dome/sb29rdnc-c000-4/
100rms
I have mine crossed at 2000hz @ 24db just to be safe, I could go lower if I played at lower volumes.
Usuable range looks to be 1000hz-20,000hz or so, need to on-axis to get best performance from them.
AudioControl DM-608
Morning bump for any other ideas or imput
  • 4 weeks later...
Chk into alpine type r tweets 150rms 400 max most of the time is over powered since there smaller but i had the rockford p1ts tweets on a rockford t400.4 amp up just a lil bit and blew them so alpine is up next for me
  • Who's Online   0 Members, 0 Anonymous, 1090 Guests (See full list)
