2015 chevy sonic lt box design
Bryont
Ok so i have a 2015 chevy sonic lt and am trying to get help with a box design for 3 12's in a ported box.
I have this space to work with in the trunk
Height = 14 inches
Width = 34 inches
Length = 22 Inches
DIAMETER: 12" (305MM)
SENSITIVITY (2.83V @ 1M): 90dB
POWER HANDLING: 275WRMS 1100WPEAK
FREQUENCY RESPONSE: 27Hz – 450Hz
NOMINAL IMPEDANCE: 4 OHMS
VOICE-COIL DIAMETER: 2" (51MM)
Dimensions: Outer Diameter 12-5/16" (313mm)
Mounting Depth 6-7/16" (164mm)
Cutout Diameter 11-1/4" (286mm)
THIELE-SMALL PARAMETERS
VOICE-COIL DC RESISTANCE: REVC (OHMS) . . . . . . 4.00
VOICE-COIL INDUCTANCE @ 1KHZ: LEVC (MH) . . . . . . . 1.26
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 82.15
SD (M2) . . . . . . . 530.00
MOTOR FORCE FACTOR: BL . . . . . . . . . 15.2
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . . 1.9
VAS (LITERS) . . . . . . 54.2
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 135.00
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 223.00
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 216.00
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 29.00
MECHANICAL Q: QMS . . . . . . . . . . . 6.39
ELECTRICAL Q: QES . . . . . . . . . . . 0.64
TOTAL Q: QTS . . . . . . . . . . . . 0.58
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . 0.315
HAG (MM) . . . . . . . . 8.00
VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 1.43
HVC (MM) . . . . . . . . 36.4
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.56
XMAX (MM) . . . . . . . 14.2
Trying to put the 3 subs top mounted with the port firing into the car.
Hopefully this is all the info i need to provide.
Thank in advance for any help
...so its a sedan...tuned in, as I have a 07 aveo sedan...very similar...you're just a little bigger (and NEWER!!)
im only doing 2 10s ported, still keeping the back seats. (daily,kids,etc.)
is this an spl build, sq, daily?
if I went three 12s, something would have to give!
B)
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
oh, and welcome to the forum!
:WELCOME:
Singer 220 amp alt
What amp are you going to be using?
You don't really have enough space for three 12"s. Even two is going to be a bit on the snug side, but may be possible.
Builds:
its a daily driver.
the space i have to work with listed is pretty much my entire trunk, except the height, i measured the height low enough so the the trunk hinges would clear the top of the box.
Also thanks for the welcome
i dont remember the amp off hand "still got to get it from my neighbor"....
just that its a 2500 watt mono amp.
i kinda figured to get them ported properly 3 might be impossible without walling off the back of the car lol, however 2 should fit easily.
So here is a suggestion for two which is what you can really do, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 7626 Guests (See full list)
