gckless Posted December 27, 2015 Report Posted December 27, 2015 I wouldn't be upset if your lights still dim after. It takes only a small amount of loss for your lights to dim, hard to avoid that with simply any alternator upgrade. A 240A hairpin should do a decent amount at idle, but remember that it takes some RPMs to wake up any alt. You still won't be getting a huge amount at idle. But it will be an upgrade for sure. You should add a battery or two though, or supercaps, to make up for the slow response (relatively speaking) of an alt. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
Irocthestreetz Posted December 27, 2015 Author Report Posted December 27, 2015 Another question, I'm running a approx 17ft run of 1/0 cca to my sq2200, am I choking my amp? I will upgrade to ofc once I get my alt but I didn't know if the wire is holding me back any right now.
Broke_Audio_Addict Posted December 27, 2015 Report Posted December 27, 2015 And I should add that my amp is a sq2200.2 pushing a hdc315. So if I went from this current setup and bought my alt, Batts, and a nother hdc3 and wired to .5 I won't experience much of a increase in sound?You would notice an increase.I would get another 2200 to go with the extra sub you want to add, then you'd notice a huge difference. And you wouldn't have to wire to .5 ohm What I'm afraid though of is buying another amp and killing off the new alternator. I feel like if Im barely getting buy with a 160a and 1 2200 that a 240a alt couldn't support two 2200s Comparing a stock type alt to a good 6 phase hairpin alt is like comparing a dog to a shark. A good 240 + amp hairpin alt and a proper battery bank will support 4K no problem. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Irocthestreetz Posted December 27, 2015 Author Report Posted December 27, 2015 I wouldn't be upset if your lights still dim after. It takes only a small amount of loss for your lights to dim, hard to avoid that with simply any alternator upgrade. A 240A hairpin should do a decent amount at idle, but remember that it takes some RPMs to wake up any alt. You still won't be getting a huge amount at idle. But it will be an upgrade for sure. You should add a battery or two though, or supercaps, to make up for the slow response (relatively speaking) of an alt. Alright good to know, I'm really just worried about straining my new alt, I'm sure my 160 is taking a beating. And I'm thinking I'll be adding at least one kinetik hc2400 at 110ah
Irocthestreetz Posted December 27, 2015 Author Report Posted December 27, 2015 And I should add that my amp is a sq2200.2 pushing a hdc315. So if I went from this current setup and bought my alt, Batts, and a nother hdc3 and wired to .5 I won't experience much of a increase in sound?You would notice an increase.I would get another 2200 to go with the extra sub you want to add, then you'd notice a huge difference. And you wouldn't have to wire to .5 ohm What I'm afraid though of is buying another amp and killing off the new alternator. I feel like if Im barely getting buy with a 160a and 1 2200 that a 240a alt couldn't support two 2200sComparing a stock type alt to a good 6 phase hairpin alt is like comparing a dog to a shark.A good 240 + amp hairpin alt and a proper battery bank will support 4K no problem. Sweet. Seems like either way I go I'm making a good choice going with a quality ho alternator. Thank you.
gckless Posted December 27, 2015 Report Posted December 27, 2015 I wouldn't be upset if your lights still dim after. It takes only a small amount of loss for your lights to dim, hard to avoid that with simply any alternator upgrade. A 240A hairpin should do a decent amount at idle, but remember that it takes some RPMs to wake up any alt. You still won't be getting a huge amount at idle. But it will be an upgrade for sure. You should add a battery or two though, or supercaps, to make up for the slow response (relatively speaking) of an alt. Alright good to know, I'm really just worried about straining my new alt, I'm sure my 160 is taking a beating. And I'm thinking I'll be adding at least one kinetik hc2400 at 110ah There are some good local batteries too if you'd rather go that route. Sears Diehard Platinum are my favorite. A little more expensive, but local and great warranty. Just throwing out options. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
Irocthestreetz Posted December 27, 2015 Author Report Posted December 27, 2015 I wouldn't be upset if your lights still dim after. It takes only a small amount of loss for your lights to dim, hard to avoid that with simply any alternator upgrade. A 240A hairpin should do a decent amount at idle, but remember that it takes some RPMs to wake up any alt. You still won't be getting a huge amount at idle. But it will be an upgrade for sure. You should add a battery or two though, or supercaps, to make up for the slow response (relatively speaking) of an alt. Alright good to know, I'm really just worried about straining my new alt, I'm sure my 160 is taking a beating. And I'm thinking I'll be adding at least one kinetik hc2400 at 110ah There are some good local batteries too if you'd rather go that route. Sears Diehard Platinum are my favorite. A little more expensive, but local and great warranty. Just throwing out options. Thank you for the suggestion I'll check them out.
Irocthestreetz Posted December 27, 2015 Author Report Posted December 27, 2015 Can someone tell me if I'm choking my 2200 with 17ft 1/0 cca pwr and ground cable?
Broke_Audio_Addict Posted December 27, 2015 Report Posted December 27, 2015 Can someone tell me if I'm choking my 2200 with 17ft 1/0 cca pwr and ground cable? What brand of wire? Personally i never use anything but ofc. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Irocthestreetz Posted December 27, 2015 Author Report Posted December 27, 2015 Soundqubed. I bout it when I ordered my system not knowing any better.
