Need help with 4th order enclosure for 3 8" subs
Jhensley209
What's your reasoning for using a bandpass box?
Builds:
i would pick a different sub, or pick a different box alignment. It would probably be tolerable in a 4th, but definitely not optimal.
Ported would be much better for those subs.
Owner of BigAss Ports
I stole this quote from CleanSierra: If the purpose of building a 4th BP is to experiment, let loose and get at it. If you're BOUND by some sort of constraints that ONLY allows a bandpass enclosure, I understand and see the need. If you're wanting a bandpass because you think it will hammer lows or be a flatter response or thinking it will outperform a standard ported enclosure(which is a 4th order btw), move on and forget it.
Builds:
They are in a good box now and sound good I just want to experiment with a different box. I need help with port options and port sizing
What amp are you using? What's your chamber sizes and tuning? With bandpass boxes you want to make sure you have ample port area since all your output is coming out that port.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 2804 Guests (See full list)
