tbeats Posted January 4, 2016 Report Posted January 4, 2016 OK so I just swapped decks today .. Same system nothing on that end changed everything sound fine. Put in my old Kenwood and noticed when I go to volume 0 or change tracks my subs make a loud thud. I tested by swapped rca with my four channel so my sub amp getting signal from the hu rear rca output I had no thud at all. So its only from that decks sw out. I used a old ground loop isolator I had an the thud was gone zero thud.. Is that my only option other then a new deck?
ShadeTreeMechanic Posted January 4, 2016 Report Posted January 4, 2016 Check the RCA shield coming out of the deck. It should be zero ohms with the radio chassis. Some pioneers had a fuse for this that would blow, I don't know about Kenwood. A simple fix is to ground the shield if its not already. I grounded my radio to the battery with a piece of 12awg and it helped a lot. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
