SQSPL50 Posted January 6, 2016 Report Posted January 6, 2016 I was putting my slot port in and i have a port opening of 4.75 in. And how this happened idk, but i measured later on and inside the box at the end of my port the opening is 5 in. What kind of effect will this have on it?
will77530 Posted January 6, 2016 Report Posted January 6, 2016 will raise the tuning, but shouldnt be anything to drastic
joef Posted January 6, 2016 Report Posted January 6, 2016 i don't think 1/8" on both sides will make a dramatic change to the tuning run it bro! u say 4 3/4 and it is 5... 1/4 to big sheeeeetttt i think thatll be fine.
ShadeTreeMechanic Posted January 6, 2016 Report Posted January 6, 2016 If its within 10% you won't notice a difference. If it was way off then put a strip of wood in the bottom of the port or make it slightly longer if you have to. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Hugh G. Rection Posted January 6, 2016 Report Posted January 6, 2016 If its within 10% you won't notice a difference. Interesting. Owner of BigAss Ports
SQSPL50 Posted January 6, 2016 Author Report Posted January 6, 2016 Alright guys, im about to put the top plate on and make the cutouts. Thanks for the input, thought id be out of 100$ worth of wood lol.
