RyanH Posted January 8, 2016 Report Posted January 8, 2016 Hey. I have been looking all over the internet for blue prints on a good dual 10 inhc subwoofer enclosure. I find one and it was for a whole different brand of sub. I built the box too and it doesn't even work. Can anyone on this forum pls help me design and really good box that I can build. I have area for 33.5 length , 18inch depth, and 12 height. Pls help!
Hugh G. Rection Posted January 8, 2016 Report Posted January 8, 2016 What do you mean the box doesnt even work? Owner of BigAss Ports
ShadeTreeMechanic Posted January 8, 2016 Report Posted January 8, 2016 Subs out of phase? If its the box i bet we can help you fix it.... Please describe old box. We can assume it is solid at the joints and doesn't leak or anything? If the it is ported you can start by blocking off the port to test. Sound better? Port is wrong. No change? Box wrong size maybe. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
MotorCityFats13 Posted January 8, 2016 Report Posted January 8, 2016 I ran a pair of the 12" kicker comps for 4 years..... in the owners manual there will be 2 box concepts for each speaker.... one called compact and one called something like sq.... its the bigger one you are looking for.... I built the one to spec for the pair of 12's and this box did awesome.... look at the manual and build a box that follows the larger of the designs and you will be golden... it even tells you the demensions of a square port.... do it as a non shared chamber box with 2 ports!
RyanH Posted January 8, 2016 Author Report Posted January 8, 2016 Subs out of phase? If its the box i bet we can help you fix it.... Please describe old box. We can assume it is solid at the joints and doesn't leak or anything? If the it is ported you can start by blocking off the port to test. Sound better? Port is wrong. No change? Box wrong size maybe. The design was actually of the internet and from this website. It was a dual box for two sundown sa-10's. Whats happening is that no air is coming out of the port. The air just moves from box to box because the port is shared by both sides if the enclosure. Also yes I made sure everything is sealed and glued properly.
RyanH Posted January 8, 2016 Author Report Posted January 8, 2016 Subs out of phase? If its the box i bet we can help you fix it.... Please describe old box. We can assume it is solid at the joints and doesn't leak or anything? If the it is ported you can start by blocking off the port to test. Sound better? Port is wrong. No change? Box wrong size maybe. I also would say that yes blocking of the port makes it sound better. However there is no air coming out if the port to begin with. How should I modify the box. I am also not sure if it is the correct size.
ShadeTreeMechanic Posted January 8, 2016 Report Posted January 8, 2016 Subs out of phase? If its the box i bet we can help you fix it.... Please describe old box. We can assume it is solid at the joints and doesn't leak or anything? If the it is ported you can start by blocking off the port to test. Sound better? Port is wrong. No change? Box wrong size maybe. I also would say that yes blocking of the port makes it sound better. However there is no air coming out if the port to begin with. How should I modify the box. I am also not sure if it is the correct size. No air out of the port but the subs are moving? Sounds like they are out of phase like one is wired backwards. One pushing while the other is pulling. Like trying to walk up the escalator that is going down. A lot of energy being applied but no work being done. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
MotorCityFats13 Posted January 9, 2016 Report Posted January 9, 2016 "The air just moves from box to box because the port is shared by both sides if the enclosure."..... for this to be true the port would have to be inside the box with a divider...lol...... its out of phase
RyanH Posted January 10, 2016 Author Report Posted January 10, 2016 "The air just moves from box to box because the port is shared by both sides if the enclosure."..... for this to be true the port would have to be inside the box with a divider...lol...... its out of phase How to I fix that
