Box and sub question
Cwallaker
Simply based on the T/S parameters,would someome be able to model how this driver might behave in a 1.47 cu sealed enclosure. 2ohm or 4ohm running aprox 500 watts
Edit* (posted T/s info below)
Modeling that wouldnt be too difficult, but accurately modeling this with cabin gain of a particular vehicle factored in is the kicker.
This is in a 2000 silverado 3 door. If that helps
Here ya go:
Blue line is raw output, green line is with a rough approximation of cabin gain added in.
Like Hugh said, the trick is estimating cabin gain. My approximation above can give you a rough idea, but your actual results could vary significantly.
With that being said, that sub looks like it will do well in a sealed box of that size. Your cone excursion should be reasonable with 500 watts.
Builds:
Here's a take from some other software, in car cabin gain is estimated:
Red = outdoors 1 cubic feet net
Green = in car 1 cubic feet net
Yellow =in car 1.5 cubic feet net (what you asked).
Cone displacement at 500W:
As you can see upsizing the sealed box result in a rather mild gain, arguably the larger box size and increased driver excursion will help the driver cool itself a little better.
Thanks guys . I was hoping my ears were right . I had it in the 1cu ft the manufacture called for. When I added .47 by removing some wood blocks , It really did sound better . Lower and louder .I need to get a computer so I can Play with these softwares . These subs are not going to win any spl contests but, they are smooth. If I wanted to try ported for more output , could I add an external port of some size to this box ? Any opinions for a tuning freq ? I listen to every thing from bon iver to gorilla Zoe .
  • Who's Online   1 Member, 0 Anonymous, 1234 Guests (See full list)
