MusicHead804 Posted February 2, 2016 Report Share Posted February 2, 2016 Is there anything wrong with eqs? will i get better sound out my speakers ? Link to comment Share on other sites More sharing options...
reedal Posted February 2, 2016 Report Share Posted February 2, 2016 In my opinion, the issue with EQ's is they are misused. They can boost or cut frequencies, and most times they are used simply to boost the frequencies that are lacking, rather than cut the frequencies that are overpowering the others. There's a limit to how much you can boost any signal and it still be a clean signal. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
MusicHead804 Posted February 2, 2016 Author Report Share Posted February 2, 2016 is it possible you can tune the eq with the one of the SMD tools? Link to comment Share on other sites More sharing options...
hdorre Posted February 2, 2016 Report Share Posted February 2, 2016 In my opinion, the issue with EQ's is they are misused. They can boost or cut frequencies, and most times they are used simply to boost the frequencies that are lacking, rather than cut the frequencies that are overpowering the others. There's a limit to how much you can boost any signal and it still be a clean signal. i LOVE this response. I wish i could like it again, and again. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted February 2, 2016 Report Share Posted February 2, 2016 To expand on what reedal said, the thing to remember with EQ is they can only reduce, they cannot add. If your system is capable of 145 db at 40 Hz and 140 db at 60 Hz, EQ can't change that. So lets say you want to boost things at 60 Hz to smooth the frequency response, so you add 5 db of boost. You aren't really boosting the signal, you are just turning everything else down 5 db. Your system can still only do 140 db at 60 Hz. The difference now is with the EQ you can only get 140 db at 40 Hz now too. This is why EQ is a lot better for fixing peaks in output rather than dips. One thing that EQ will work very well for is reducing the peakyness of peaky subwoofer boxes. It costs you max output, but its super easy to do and you can adjust things all you want. You can turn the EQ off for when you want to make a big number and then turn it back on when you want your system to sound decent. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
reedal Posted February 2, 2016 Report Share Posted February 2, 2016 In my opinion, the issue with EQ's is they are misused. They can boost or cut frequencies, and most times they are used simply to boost the frequencies that are lacking, rather than cut the frequencies that are overpowering the others. There's a limit to how much you can boost any signal and it still be a clean signal.i LOVE this response. I wish i could like it again, and again. Thank you. I'm trying to cut down on all of the novel-length responses I typically give, so it was semi-short and sweet SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
reedal Posted February 2, 2016 Report Share Posted February 2, 2016 To expand on what reedal said, the thing to remember with EQ is they can only reduce, they cannot add. If your system is capable of 145 db at 40 Hz and 140 db at 60 Hz, EQ can't change that. So lets say you want to boost things at 60 Hz to smooth the frequency response, so you add 5 db of boost. You aren't really boosting the signal, you are just turning everything else down 5 db. Your system can still only do 140 db at 60 Hz. The difference now is with the EQ you can only get 140 db at 40 Hz now too. This is why EQ is a lot better for fixing peaks in output rather than dips. One thing that EQ will work very well for is reducing the peakyness of peaky subwoofer boxes. It costs you max output, but its super easy to do and you can adjust things all you want. You can turn the EQ off for when you want to make a big number and then turn it back on when you want your system to sound decent. This kind of blew my mind, and has me considering my response now. If there is no "adding" to the signal, then how does my 80prs EQ (from my testing experience when using EQ with DD-1) cause distortion when I increase the frequency or the closest to that of which I am playing? Because, if it does not raise the output of the frequencies being boosted, then it should not cause distortion by doing so, correct? And that brings me to another question. The PAC LC-1, is a gain knob, which is not powered by its own supply, but only has the voltage from the RCA's, so how could it increase the voltage or introduce clipping/distortion when turning it up (gain set with knob turned down) when it doesn't have an powered amplifier in it? I'm curious to see what the answer is. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted February 2, 2016 Report Share Posted February 2, 2016 I think it is all relative. The point of max signal without distortion is "X". Then you boost a frequency. You can't go above "X" signal so in effect the signal you boosted is "X" and now the rest are lower than "X". When you boost it reaches max first causing everything else to be lower than max. The Pac LC-1 is an attenuator not a booster. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted February 3, 2016 Report Share Posted February 3, 2016 ShadeTreeMechanic pretty much nailed it. EQ just adjusts level relative to everything else. It can't make your system louder. It can just make certain frequencies sound louder (or softer) relative to the rest of the spectrum. Any time you use EQ it eats into your head room and will cost you output somewhere. Depending on what you are trying to do, giving up a little potential output may be a small price to pay for better frequency response. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
reedal Posted February 3, 2016 Report Share Posted February 3, 2016 If it is only an attenuator, then it should not be able to clip the signal or raise the output if you set gains with the LC-1 knob all the way down, and then turn the knob all the way up. Because an attenuator is just an attenuator. It can't increase or boost the signal. (I have not yet used my LC-1, but I think when I get my dash finished and the knob hooked up I will test for distortion when I have the knob all the way down when setting the knob) And as for the EQ, that still doesn't explain how the 80prs EQ (the only EQ I have experience with) can introduce distortion when "boosting" a signal to see the max clean. If you already have max clean, and EQ can't raise it above what your clean is, then how can it introduce distortion by simply attenuating the rest of the frequencies down to its level? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
