Jonathan Tyler Ecton-Rodriguez Posted February 5, 2016 Report Posted February 5, 2016 Designed it for an HDC4 15" 4.26 cu.ft. @35hz 75 sq.in of port anything i could've done better? I appreciate all the tips and advice i've been given to get me this far
Skullz Posted February 5, 2016 Report Posted February 5, 2016 Overly complex, let your ports use the top and bottom of the box which use less materials and easier to construct. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Jonathan Tyler Ecton-Rodriguez Posted February 5, 2016 Author Report Posted February 5, 2016 Overly complex, let your ports use the top and bottom of the box which use less materials and easier to construct. as long as overly complex doesnt affect performance lol, the guy i designed it for wanted something like this with bracing
audiofanaticz Posted February 5, 2016 Report Posted February 5, 2016 The port running the verticle height of the box would add to top and bottom panel bracing. I always avoid making a port with 3 or 4 sides that are not in contact with the rest of the enclosure due to that alone.
Triticum Agricolam Posted February 6, 2016 Report Posted February 6, 2016 Like others have said, having your port panels connect the top and bottom will make the box SIGNIFICANTLY stronger. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jessica Posted February 6, 2016 Report Posted February 6, 2016 its a nice design, and with some skill it could be built. i see you are wanting to get away from a higher ratio port opening and thats good. i would say do a 3 common wall port. save some material and get some free bracing and not worry about the ratio. Thats just my .02. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
