Crimping 1/0
I've asked this before, been told to use the 70 mm dies. But when I do and fully crimp these baby's my xs power wire is easily pulled out of the crimp with about 30ish lbs of pressure applied. So I tried using the 50 mm dies, and this happens:
D9BFBDC8-B050-4F2F-A3F0-1D85F4802556_zps
Hard to see from the pic but the "wings" that this crimp left are almost 1/2" long. But the wire ain't coming out of this crimp. Will this crimp cause any issues?
Btw this is just a test crimp, not going to be used at all.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
use the 70mm first then put the 50mm in, just dont fully crimp down.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
Thanks I will try that
Subs/Amps: TBD
Your terminal is too big for your wire. I did this too when I first got my crimper.
When you put the wire in it should barely fit as in the first time you put it in you say to yourself "its not going to fit" then you make all the strands really straight and try a few more times and then you get it. It has to completely fill up the terminal before crimping in order to make a gas tight seal. Otherwise you will not achieve a proper cold weld and will do just as well to crimp it with a hammer. I will see if I can find a picture.
Pioneer 80PRS
Ok, so I need to purchase different lugs? These are sky high 1/0 lugs, on what I was told oversized 1/0 in the XS Power Flex. I couldn't fit the wire into the lug until i twisted the shit out of the copper strands, at that point it was loose though. Who should I get new lugs from??
Subs/Amps: TBD
stop using metric crimper dies on sae lugs.
also, how many tons is your crimper, my 12 ton could never do that but my 16 ton just does not stop. i could just keep sticking smaller dies in until i make a wormhole.
I'm not sure about car audio brands. I use welding cable and copper lugs that are nickel plated for corrosion resistance. The lugs I use are standard for welding and battery cables. Do a search on ebay for 1/0 lugs. If I twist the strands then they will not go in. They have to be really straight and just stripped. Maybe the SHCA are sized for their cable? If you are using XS cable then maybe XS lugs will fit better?
Pioneer 80PRS
It's a 16 ton, got a hell of a deal on it, but was metric. I'm going to see if I can make it work by getting a good hold with the 70 mm and then crimping until tight with the 50's. If that doesn't work I will try to buy some different lugs. Think the ones from knukonceptz would work better?
Subs/Amps: TBD
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
