SCATHED Posted February 8, 2016 Author Report Share Posted February 8, 2016 Right now the box for the BL is probably a little short on port area. It's 2.3 cubes net tuned to 35hz with three 3" aero ports. Sub is on 2000 watts. Thoughts on the box? Should I shrink it down since the sub is being overpowered a little? My goal is to just get the loudest I can with the space that I have. With three 3" aero ports you are a LOT short on port area. You should probably around 35-40 sq in of port and right now you have 21. You COULD gain significant output just from rebuilding your current box with a more appropriate amount of port. should i build a smaller box? Link to comment Share on other sites More sharing options...
Joe X Posted February 8, 2016 Report Share Posted February 8, 2016 Right now the box for the BL is probably a little short on port area. It's 2.3 cubes net tuned to 35hz with three 3" aero ports. Sub is on 2000 watts. Thoughts on the box? Should I shrink it down since the sub is being overpowered a little? My goal is to just get the loudest I can with the space that I have. You are needing about 40 square inches of port area for the sub on those conditions. Pretty sure low port area it's costing you output. Link to comment Share on other sites More sharing options...
SCATHED Posted February 8, 2016 Author Report Share Posted February 8, 2016 I'm having trouble getting the length right for three 4" aeros. I might go with a slot port firing to the passenger side Link to comment Share on other sites More sharing options...
SCATHED Posted February 8, 2016 Author Report Share Posted February 8, 2016 I have an 8" octoport that I can use, but that's 64" of port area Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted February 8, 2016 Report Share Posted February 8, 2016 I have an 8" octoport that I can use, but that's 64" of port area I guess it depends on how you are measuring it, but an 8" octoport should't be 64 sq of area, it should be less. It would have to be a mile long though to get your tuning where you want. As far as your box size goes, if you aren't having excursion problems with it now, there really isn't much reason to build it smaller. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
WCA Rusty Posted February 9, 2016 Report Share Posted February 9, 2016 I have a single cab truck so space is limited. What 12" subs perform well in small ported boxes? I know DC Audio subs do well in that category but are there any others? your right, all our subs do well in small boxes DC AUDIO Phone Number 1(855)SPL-DBZZ Built by Competitors, for Competitors. Link to comment Share on other sites More sharing options...
SCATHED Posted February 9, 2016 Author Report Share Posted February 9, 2016 I can build boxes fine, but as far as designing and coming up with exact measurements, I'm not so good at. This is the box it's in now Link to comment Share on other sites More sharing options...
SCATHED Posted February 9, 2016 Author Report Share Posted February 9, 2016 Can someone who is good at designing/enjoys designing boxes design a box for an Fi BL 12 that is within the space that I have? Powered by crescendo bc2000. Here is the space I have but I can go smaller since it's getting overpowered. I just want the most optimum box for the sub. Space available is... Width: 40 Height: 20 Top Depth: 6 Bottom Depth: 10 Link to comment Share on other sites More sharing options...
Joe X Posted February 9, 2016 Report Share Posted February 9, 2016 Can you give the dimensions for the box in the pic and the length of the ports? Link to comment Share on other sites More sharing options...
SCATHED Posted February 10, 2016 Author Report Share Posted February 10, 2016 Can you give the dimensions for the box in the pic and the length of the ports? Outside Dimensions: Width: 40 Height: 19 Top Depth: 6 Bottom Depth: 10 Three 3" aeros at 17" long Link to comment Share on other sites More sharing options...
