dturro Posted February 9, 2016 Report Posted February 9, 2016 One question guys, on the # of common port walls option should i chose 3? this is the only thing i cannot understand. Port is 12x2.5x38. I researched a lot but the pictures provided on the help menu of torres calculator are no longer available. Port Will be made on one side of the box. Thank you for any input.
Skullz Posted February 9, 2016 Report Posted February 9, 2016 Port walls are ones that make up the sub enclosure, so the max you can have is 3. Any wall that is not part of the outer enclosure they do not count. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Hugh G. Rection Posted February 9, 2016 Report Posted February 9, 2016 It would be nice however if torres had an input section for which port walls are common. With knowing which ones, it is a useless feature. Owner of BigAss Ports
Joe X Posted February 9, 2016 Report Posted February 9, 2016 One question guys, on the # of common port walls option should i chose 3? this is the only thing i cannot understand. Port is 12x2.5x38. I researched a lot but the pictures provided on the help menu of torres calculator are no longer available. Port Will be made on one side of the box. Thank you for any input. If your port is like in the picture below you should set 3 to the number of common walls.
dturro Posted February 10, 2016 Author Report Posted February 10, 2016 One question guys, on the # of common port walls option should i chose 3? this is the only thing i cannot understand. Port is 12x2.5x38. I researched a lot but the pictures provided on the help menu of torres calculator are no longer available. Port Will be made on one side of the box. Thank you for any input. If your port is like in the picture below you should set 3 to the number of common walls. yes, the port will be like that one. But what if it takes all the back wall and some of the left by looking at the picture example.? that is also 3 right?
dturro Posted February 10, 2016 Author Report Posted February 10, 2016 It would be nice however if torres had an input section for which port walls are common. With knowing which ones, it is a useless feature. yes, that would be great, unfortunately is does not, and it is kind of hard to figure this future by someone that has not used the program before
Joe X Posted February 10, 2016 Report Posted February 10, 2016 yes, the port will be like that one. But what if it takes all the back wall and some of the left by looking at the picture example.? that is also 3 right? That won't matter it's still 3 common walls.
dturro Posted February 10, 2016 Author Report Posted February 10, 2016 yes, the port will be like that one. But what if it takes all the back wall and some of the left by looking at the picture example.? that is also 3 right? That won't matter it's still 3 common walls. good, thanks for the help.
