Brad Majors Posted February 29, 2016 Author Report Posted February 29, 2016 Do it like in this last sketch of yours and it will be good. awesome. thank you for your time of the first sketch up and figures for me.
Brad Majors Posted March 4, 2016 Author Report Posted March 4, 2016 Do it like in this last sketch of yours and it will be good. Hey man one last check ( sorry im anal ) i keep running this box over and over in all my calculators and keep coming up with 39-40 hz tuning. i know you showed it to be tuned to 35 hz but the only way i see it to get that low would be to have port opening at like 4.5 inches wide. not calling you wrong or anything man just wanting to make sure ive got everything perfect before i build it. also i read that SQ subs like big boxes high tuning and im assuming thats why u designed it this way but just like being sure is all man and again thanks for everything
ckeeler11 Posted March 4, 2016 Report Posted March 4, 2016 also i read that SQ subs like big boxes high tuning and im assuming thats why u designed it this way but just like being sure is all man and again thanks for everything SQ builds usually have lower tuning 30-35 hz. SPL set-ups are higher.
Brad Majors Posted March 4, 2016 Author Report Posted March 4, 2016 was meaning SQ as in SoundQuebed not Sound Quality.
reedal Posted March 4, 2016 Report Posted March 4, 2016 Do it like in this last sketch of yours and it will be good.Hey man one last check ( sorry im anal ) i keep running this box over and over in all my calculators and keep coming up with 39-40 hz tuning. i know you showed it to be tuned to 35 hz but the only way i see it to get that low would be to have port opening at like 4.5 inches wide. not calling you wrong or anything man just wanting to make sure ive got everything perfect before i build it.also i read that SQ subs like big boxes high tuning and im assuming thats why u designed it this way but just like being sure is all man and again thanks for everything Something joe is accounting for that all of the box calcs don't is the effect your cabin will have on tuning of the enclosure. I believe that is why his tuning is different from the others. That and the software he is using SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Joe X Posted March 4, 2016 Report Posted March 4, 2016 Do it like in this last sketch of yours and it will be good. Hey man one last check ( sorry im anal ) i keep running this box over and over in all my calculators and keep coming up with 39-40 hz tuning. i know you showed it to be tuned to 35 hz but the only way i see it to get that low would be to have port opening at like 4.5 inches wide. not calling you wrong or anything man just wanting to make sure ive got everything perfect before i build it. also i read that SQ subs like big boxes high tuning and im assuming thats why u designed it this way but just like being sure is all man and again thanks for everything It's a shared port box not common chamber and then you need to apply the end correction for slot ports both effects will lower tuning, lastly you are leaving out the 1 5/16" extensions out so it may tune a little higher than stated but not as much as 40Hz.
Brad Majors Posted March 5, 2016 Author Report Posted March 5, 2016 Do it like in this last sketch of yours and it will be good. Hey man one last check ( sorry im anal ) i keep running this box over and over in all my calculators and keep coming up with 39-40 hz tuning. i know you showed it to be tuned to 35 hz but the only way i see it to get that low would be to have port opening at like 4.5 inches wide. not calling you wrong or anything man just wanting to make sure ive got everything perfect before i build it. also i read that SQ subs like big boxes high tuning and im assuming thats why u designed it this way but just like being sure is all man and again thanks for everything It's a shared port box not common chamber and then you need to apply the end correction for slot ports both effects will lower tuning, lastly you are leaving out the 1 5/16" extensions out so it may tune a little higher than stated but not as much as 40Hz. right on man. i know calcs arent perfect and thats why i ask. excited to get this built because they slam as it is in my box i have now so cant wait for this one. picking up supplies tomorrow and starting and hopefully finishing tomorrow as well. thanks again
Brad Majors Posted March 14, 2016 Author Report Posted March 14, 2016 Do it like in this last sketch of yours and it will be good. Hey man one last check ( sorry im anal ) i keep running this box over and over in all my calculators and keep coming up with 39-40 hz tuning. i know you showed it to be tuned to 35 hz but the only way i see it to get that low would be to have port opening at like 4.5 inches wide. not calling you wrong or anything man just wanting to make sure ive got everything perfect before i build it. also i read that SQ subs like big boxes high tuning and im assuming thats why u designed it this way but just like being sure is all man and again thanks for everything It's a shared port box not common chamber and then you need to apply the end correction for slot ports both effects will lower tuning, lastly you are leaving out the 1 5/16" extensions out so it may tune a little higher than stated but not as much as 40Hz. Okay well update I got it all built and man does it rock THANK YOU. put it in the lane at AR SPL and turned a 146.5 and found peak freq last 3 seconds of the run lol doors shut. SO interested to see what it will do with some tweaking and such. but again thank you for the amazing design. Now ima aim for a fart box just to break 150s just for shows. If you have any pointers there let me know. thanks.
