Mike Gann Posted February 19, 2016 Report Posted February 19, 2016 Hello there, Simple question here, should I use wood glue or can I get away with only using wood calk / adhesive to glue together baffles. I will be using fasteners as well. My Ford Fiesta build log: http://www.fiestafaction.com/forums/threads/42371-Building-a-Fiesta-Sized-Subwoofer-Box
ALPINE408 Posted February 19, 2016 Report Posted February 19, 2016 there is no replacement for wood glue not liquid nails not calk not silicone WOOD GLUE! is the best Have you ever had your woofers blown?
Mike Gann Posted February 19, 2016 Author Report Posted February 19, 2016 What is the best way to get the calk in the corners of a ported enclosure lets say. I usually caulk the rear chamber but it's hard to get any inside the port. Is wood glue good enough for all of this, maybe I'm putting too much thought into it My Ford Fiesta build log: http://www.fiestafaction.com/forums/threads/42371-Building-a-Fiesta-Sized-Subwoofer-Box
Skullz Posted February 19, 2016 Report Posted February 19, 2016 I never use anything but glue on the box, not in the corners or anywhere, some people like to use a silicone caulk in the corners, but it is not needed. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Mike Gann Posted February 19, 2016 Author Report Posted February 19, 2016 Alright I'll just keep doing what I'm doing then, thanks. My Ford Fiesta build log: http://www.fiestafaction.com/forums/threads/42371-Building-a-Fiesta-Sized-Subwoofer-Box
_paralyzed_ Posted February 19, 2016 Report Posted February 19, 2016 Use titebond 2. You really don't need fasteners if you use the proper glue. When glued properly with the right glue the wood will rip apart before the glue joint will.
