XS Power
you don't have to run a ground to the front. Just ground to a thick piece of metal in the rear.
if he dont have a solid ground he will have to run it to the front.. the panel is not stout enough to carry grounds.. also there are body bushing with rubber that can affect the current.. the best ground is the frame.. if there is frame under the trunk he will have to drill a hole to ground to it.. if its a unibody he will have to run the grounds to the front or find a way to connect the front frame to the rear frame
You're missing the point. he thinks you HAVE to run a ground to the front. which is false.
youre missing the point.. its all dependent. you dont know what car he has and the shop might be right about running the grounds to the front
fucking christ. because when hasn't a shop tried to weasel more money out of you. "yeah you're gonna need another run of 1/0 so you can ground your batteries to the front"
Give me an example of a car that you can't ground in the rear of the car, let alone the frame.
i just said what cars need to have grounds running to the front.. a unibody car.. a fox body mustang being one of them, Jesus Christ.. they have no frame connecting the front to the rear and all that keeps them together is a bushing with rubber on it.. why do you think you need to ground the alternator to the battery? could it be because the heads have a gaskets that affects the path of return.. not all cars need to have the grounds running to the front but many do. or you have to find a way to ground the rear frame correctly because a bushing with a rubber is not sufficient enough.. yeah there might be ground back there but could have resistance
lets find out what car he has first to see if the shop wants to take him on his money
In general:
  • All of your batteries in the back should be grounded to each other and at LEAST one run grounded to the frame in the back.
  • All of your batteries in the back should have all positive cables connected to each other and at LEAST one run going to the front of the vehicle (connected to either Bat+ or Alt+)
I think this is what the shop was trying to say.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 1404 Guests (See full list)
