ok so i just bought that today and it should be in friday. i have a 97 chevy c1500 and need help locating the vss (car speed signal input) wire, and the reverse gear signal wire. any idea on where they are and what color? ill be posting pix up of the install if you guys want them. just lemme know, and please help!! :^
If I remember correctly the vss wire is white in the ecm under the hood by the batt.
next to green .
o wait........ behind radio green with white in the radio harness.
and you only need rev. signal for use with a backup camera.
if you need that its in the ign. harness. must test.
or find in in the harness going to rear in the drvr side sill plate.
Off the top of my head of course, ill try to remember to look later for you, but that should do it.. and always use a dmm when testing.
I thought the reverse wire was for the GPS, so it knows how far you have reversed, ect ect
precisely. if u turn while in reverse, it thinks u turned while in drive so if u make a 90, u actually made a 180 and are goin north instead of south lol.
no it does not..
no need for reverse.
no it does not..
well thats what it says in the manual. anyway, heres some diagrams. it says it goes to my radio with a dark green/white wire, but there in no wire of such in my radio diagram.....
i have never hooked up rev. wire..
its for a rear camera input, the navi knows where your at via the gps ant.
most of the time you dont even need the vss wire.
sure its yours hook everything up, hell i prob. would in my car too. If i was rich enough to have 1.
  • Who's Online   0 Members, 0 Anonymous, 984 Guests (See full list)
