boom50cal Posted March 19, 2016 Report Share Posted March 19, 2016 if it's on a newer vehicle with ABS, a lot of the time you can get them to enact a "self bleed" if you will, by performing a rapid stop on a loose surface that will cause the ABS to engage. Most service shops have an IDS scan tool that will cause the ABS to cycle... but if it's on the foxbody in your sig, take it back. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
Masterbasser Posted March 19, 2016 Author Report Share Posted March 19, 2016 yea i left a message, ill call again monday and let em know needs to be done asap , yes it is the foxbody in my sig. tryna get it all squared up this year before I start chuckin group 31s in it Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl Link to comment Share on other sites More sharing options...
RoadWarrior Posted March 24, 2016 Report Share Posted March 24, 2016 MB , did they get you fixed up ? Link to comment Share on other sites More sharing options...
Masterbasser Posted April 17, 2016 Author Report Share Posted April 17, 2016 Updated* The brakes fixed themselves over the weekend after the work was done, I think it was "brake pedal knockback" from the more efficiently functioning calipers in the rear Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted April 18, 2016 Report Share Posted April 18, 2016 The brakes fixed themselves? That sounds scary. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
3vil Posted April 18, 2016 Report Share Posted April 18, 2016 Yeah, braking systems aren't really self repairing. Link to comment Share on other sites More sharing options...
RoadWarrior Posted April 18, 2016 Report Share Posted April 18, 2016 "brake pedal knockback" ? Now there is a new term, for me any ways. I love it when brakes fix themselves. It could have been that the pads just needed broke in which is rare or the pads they installed were made out of different materials than your old ones giving you a different feel in the brake pedal. For the most part anytime you replace the rear pads or shoes on a vehicle it will help the pedal immediately, I call them big toe brakes and that is the way I like them. Link to comment Share on other sites More sharing options...
