RooTxBeeR Posted April 5, 2016 Report Posted April 5, 2016 3 and 3/0 are different. When it is in that size, I was told it is pronounced like, ott. Welding wire sizes. And to post a picture. Get a link of it, and click the little picture in the post, where you adjust size and font. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
GS300Cali93 Posted April 5, 2016 Author Report Posted April 5, 2016 3 and 3/0 are different. When it is in that size, I was told it is pronounced like, ott. Welding wire sizes. And to post a picture. Get a link of it, and click the little picture in the post, where you adjust size and font. Is 3/0 bigger? Better then 1/0 or 00
ShadeTreeMechanic Posted April 6, 2016 Report Posted April 6, 2016 3/0 = 000, 2/0 = 00, 1/0 = 0 3/0 is bigger than 1/0 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
RooTxBeeR Posted April 6, 2016 Report Posted April 6, 2016 3 and 3/0 are different. When it is in that size, I was told it is pronounced like, ott. Welding wire sizes. And to post a picture. Get a link of it, and click the little picture in the post, where you adjust size and font. Is 3/0 bigger? Better then 1/0 or 00 yes, 3/0 is bigger than 3. It starts at higher numbers, which are smaller thickness. So like 10-16ga is speaker wire. 8ga is sub wire, and 2ga or thicker is power wire. Once it reaches 1 or 0, then it starts going back up but with a /0 after it. So 1/0, 2/0, 4/0, much thicker wires. I believe, 1/0 and 00 are the same, I think, not 100% on that. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
