X-15 D2 Box Help
I have two X-15 D4's in 3.5 net each @ 35 in my Bug and love it! I did have one in 4.25 net @ 32 and it sounded wonderful too! IDK if the juice would be worth the squeeze making marginal changes. Remember, they naturally play low.
I'm going from 3 12's to this so it might just take some getting used to and once the sub is broken in so I can hear it better, it just seems like its hitting high to me
Is it new? I noticed it hitting lower after a week or two playing it.
Also would you recommend that the port be pointed at the trunk or into the cabin. The shop installed it facing the cabin but I've always pointed boxes with ports towards the trunk.
Trunk? Turn that bad boy around unless you're sealed off. You'll probably notice a big difference right there.
I'd get your money back from the shop. It's one thing to bring gear, and tell them to make it work. But to say, I need it to be like x, and they fail. No Bueno
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I recently purchased a Sundown Audio X 15 D2 paired with a scv-1500d.Ihave never built a box before so I had a local shop build one for me. To my understanding this speaker preforms best in a box tuned to 32hz. I told the shop that I need this built to this frequency but I believe they did not. They built a slot port box, 33.5x20.75x16.5 with a 15.5x23x4 port, with 1 inch wood. After calculating this on numerous box calculators I come up with around 40 Hz. I'm interested in knowing if these calculations are correct and if so what, if possible what the correct dimensions should be with this box. The 33.5 and 16.5 are maxed out on my trunk space but it could've been built up to 8 inches longer. Thank you for any of your help.
how is the port 15.5 with 1"? it should be 14.5 still about 4.29 tuned to 34.. It will work but its not what you asked for..
  • Who's Online   1 Member, 0 Anonymous, 1019 Guests (See full list)
