2002 Expediton Budget Build/Re-build 4-AB XFL15's and Rockford FTW
[sharedmedia=garage:vehicles:3176]
Time to put this build on paper. It's already 95% complete because this was the rebuild and I did all the work in the past few weeks (Power wire, RCA's, alt, etc was already installed) I just hate taking pics and working at the same time so i saved them to the end. It has the following:
Head Unit: JVC KW-AVX740
Other Sources: Samsung 8.0 tablet
Amplifiers: (2) BRX2400.1, (1) BRX640.4
Mids and Highs: (2) 6.5 RF-P165 , (1) 6x9 RF-P1692
Sub Woofer(s): (4) American Bass XFL1544
Speaker Enclosure: 13.5 cubes net tuned to 33.6hz
Signal Wires: All Stinger 4000 series
Power Cables: (2) runs of 1/0, Big 4 upgrade, all Sky High FTW
Processing: Clarion EQS746
Alternator Brand/Power: Mechman 240
Battery/Batteries: Exide AGM 65 front, (2) AGM 31's in rear
160 sq ft of Noico deadner. Roof, floors, and doors (some areas triple COVERAGE)
Click in the field where it says img and it turns yellow and says copied. Go to your post and paste it in
and it will look like this:
[ URL=http:/ /s1148.photobucket.com/user/########/media/2_zps4wrfxxsi.png.html] [/url ]
Then press enter, repeat for however many pics you want to insert, and type where you want to type.
Well here is the engine bay. It's a bit dirty but you can see 2 runs of 1/0 Sky High and the big 4 on Mechman 240 laid out neatly with plenty of zip ties. The battery is an Exide 6500 AGM. I've had good luck with these.
Also forgot to add I have a 500 amp relay from Install bay. That's the little black can that the 2 runs are going into. Yeah, Yeah I know I don't need this but I used to tailgate and run my power inverter of my rear batts​ so I wouldn't draining the main batt. This was before the upgrade though.
